22 October 2026, 05:45:44
Кордон-М2 (тыл)
Russian Federation > Ивановская область
07 April 2022, 17:20:09
07 April 2022, 18:01:54
roma012009@rambler.ru, changed control area.
roma012009@rambler.ru, changed control direction from Counter direction to In the back.
07 April 2022, 18:03:17
Timon34, changed warning direction from 147 to 148.
Timon34, changed object description from 'Кордон-М2' to 'Кордон-М2 (тыл)'.
07 April 2022, 18:05:02
roma012009@rambler.ru, changed object latitude from 39.704619 to 39.704315
roma012009@rambler.ru, changed object longitude from 57.009532 to 57.009793
04 July 2022, 18:12:13
sademid51, changed control area.
sademid51, changed object notification distance from 400 to 550.
26 January 2025, 17:48:09
Прошу удалить, столб пустой
29 January 2025, 06:26:24
Отсутствует -1
29 January 2025, 06:26:27
Отсутствует -1
29 January 2025, 06:26:29
Отсутствует -1
29 January 2025, 07:53:52
По просьбе Удалил -1
29 January 2025, 07:53:54
29 January 2025, 07:53:57
29 January 2025, 07:54:41
, changed object notification distance from 550 to 100.
23 January 2026, 16:58:30
Ребята, прошу прощенья, подмена GPS была сильная, по видео посмотрел и сравнил с картой, эта камера на месте, работает.
23 January 2026, 16:59:01
Ошибочное понижение +1
23 January 2026, 16:59:05
23 January 2026, 16:59:08
23 January 2026, 17:01:08
, changed object notification distance from 100 to 550.
23 January 2026, 17:20:54
См выше +1
23 January 2026, 17:20:59
См выше +1
23 January 2026, 17:21:03
См выше +1
19 September 2026, 09:38:55
19 September 2026, 09:40:56
Похоже, камера на этом столбе была когда-то. GPS проверены, можно удалять.
19 September 2026, 09:41:14
Отсутствует -1
19 September 2026, 09:41:17
Отсутствует -1
19 September 2026, 09:41:20
Отсутствует -1
19 September 2026, 09:41:44
19 September 2026, 10:10:33
Выше Удалил -1
19 September 2026, 10:10:36
Выше Удалил -1
19 September 2026, 10:10:39
Выше Удалил -1
