21 November 2026, 00:25:16
Стрелка-М-Р [121км 800м]
04 January 2019, 13:20:29
04 January 2019, 13:29:26
3D_MASTER, changed object latitude from 39.486950 to 39.487486
3D_MASTER, changed object longitude from 55.942258 to 55.942336
3D_MASTER, changed speed limit from 50 to 60.
3D_MASTER, changed speed limit from 0 to 60.
3D_MASTER, changed warning direction type from Two directions to In a certain direction.
3D_MASTER, changed warning direction from 78 to 79.
3D_MASTER, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Статическая камера, измеряющая скорость'.
3D_MASTER, confirmed object added via Mapcam.info program
04 January 2019, 13:35:09
Поправьте, кто часто там катается. Ставил на скорости.
04 January 2019, 13:42:25
3D_MASTER, changed object description from 'Статическая камера, измеряющая скорость' to 'АвтоУраган ВСМ-2'.
3D_MASTER, changed camera model.
04 January 2019, 16:07:20
31 January 2019, 11:17:00
03 February 2019, 13:13:02
3D_MASTER, changed object latitude from 39.487487 to 39.487739
3D_MASTER, changed object longitude from 55.942336 to 55.942341
03 February 2019, 13:13:39
поставил точнее
03 February 2019, 13:20:20
3D_MASTER, changed warning end time from 24 to 0.
04 February 2019, 09:35:02
Автор, на что больше похож комплекс, на АвтоУраган или Стрелка-МР ?
05 February 2019, 08:14:39
05 February 2019, 13:18:16
Рейтинг НОЛЬ до подтверждения. Ящиков нет. Вероятно муляж. -1
05 February 2019, 13:18:23
12 February 2019, 14:09:49
Alex_190, changed object notification distance from 500 to 250.
Alex_190, changed object view angle from 15 to 20.
Alex_190, changed object description from 'АвтоУраган ВСМ-2' to 'Стрелка-М-Р'.
Alex_190, changed camera model.
20 May 2019, 06:17:47
Поднимаю до рабочего +1
20 May 2019, 06:17:51
13 August 2019, 07:02:11
камера работает +1
13 August 2019, 07:27:35
Есть подтверждение?
25 January 2020, 16:16:52
CJ_009, changed object notification distance from 250 to 400.
CJ_009, changed object view angle from 20 to 15.
25 January 2020, 16:17:12
Коррекция дистанции.
07 February 2020, 09:54:05
fantompg, changed object description from 'Стрелка-М-Р' to 'Стрелка-М-Р [122км 250м]'.
15 April 2020, 05:29:31
15 April 2020, 05:29:37
15 April 2020, 05:31:14
подтверждено +1
06 June 2020, 13:39:02
fantompg, changed object notification distance from 400 to 450.
01 July 2020, 16:31:47
01 July 2020, 16:32:05
12.9 ч.6 - повторное совершение административного правонарушения, предусмотренного частью 3 настоящей статьи
23 November 2020, 07:41:39
01 December 2020, 12:22:54
fantompg, changed object description from 'Стрелка-М-Р [122км 250м]' to 'Стрелка-М-Р [121км 800м]'.
25 March 2021, 18:10:40
04 August 2022, 09:38:34
04 August 2022, 09:38:58
23 November 2022, 09:41:15
23 November 2022, 09:45:06
Ни камеры ни кронштейна не увидел. На дороге работы.
23 November 2022, 11:49:02
До 0 -1
23 November 2022, 11:49:06
До 0 -1
23 November 2022, 11:59:31
До 0, завершено -1
23 November 2022, 11:59:36
До 0, завершено -1
03 November 2023, 12:15:52
Отсутствует -1
03 November 2023, 12:15:56
Отсутствует -1
03 November 2023, 12:15:59
Отсутствует -1
13 January 2025, 00:00:14
Повесили... Пищит...
24 January 2025, 05:56:07
Повесили +1
24 January 2025, 05:56:11
Повесили +1
24 January 2025, 05:56:13
Повесили +1
11 February 2025, 10:50:42
На месте. Актуализировал. +1
11 February 2025, 10:50:45
