22 October 2026, 06:53:01
Контроль скорости
29 June 2015, 15:50:15
01 July 2015, 11:55:11
scenic1982, changed object type from  Static speed camera Static speed camera to  Portable Camera (trap) Portable Camera (trap).
scenic1982, changed speed limit from 60 to 90.
scenic1982, changed warning direction type from Two directions to In a certain direction.
scenic1982, changed warning direction from 142 to 147.
scenic1982, changed object notification distance from 500 to 432.
scenic1982, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Стоит тренога на обочине'.
scenic1982, confirmed object added via Mapcam.info program
01 July 2015, 14:29:16
silandser, changed object notification distance from 432 to 500.
28 September 2015, 19:18:21
2maxic, changed object description from 'Стоит тренога на обочине' to 'Контроль скорости'.
23 May 2017, 15:26:59
Насколько актуальна данная точка судить не могу, но факт, что на перекрёстке с поворотом на Тюбук установлен светофор.
01 July 2020, 14:17:04
:-), changed speed limit from 90 to 70.
05 March 2025, 16:09:51
без подтверждений с 2015г. -1
05 March 2025, 16:09:54
05 March 2025, 16:09:56
05 March 2025, 16:27:48
05 March 2025, 16:27:52
05 March 2025, 16:27:54
05 March 2025, 18:12:09
