23 October 2026, 05:53:23
СКАТ-П [93км 800м]
12 February 2020, 14:32:16
12 February 2020, 18:30:45
12 February 2020, 18:37:28
Здесь 2 комплекса установлено?
13 February 2020, 06:22:38
Было замечено 2шт в разные стороны.
06 March 2020, 19:27:25
Подтверждено 2020-02-22 08:24:01 (UTC±00:00)
     Вероятность: 90 %  (Частота за прошлый месяц)
24 August 2020, 08:01:00
28 September 2020, 20:00:14
himych, changed object latitude from 38.642428 to 38.639040
himych, changed object longitude from 55.208892 to 55.210720
28 September 2020, 20:00:53
28 September 2020, 20:04:00
himych, changed warning direction type from In a certain direction to Two directions.
28 September 2020, 21:53:16
balabol.1974, changed object notification distance from 753 to 800.
balabol.1974, changed object view angle from 15 to 45.
balabol.1974, changed object description from 'ОСКОН' to 'СКАТ-П'.
29 October 2020, 17:14:05
Стояли.
29 October 2020, 17:29:18
White_52, changed object latitude from 38.639040 to 38.639721
White_52, changed object longitude from 55.210720 to 55.210293
White_52, changed warning direction type from Two directions to In a certain direction.
White_52, changed object view angle from 45 to 30.
31 January 2021, 18:46:48
31 January 2021, 18:47:07
31 January 2021, 18:47:10
31 January 2021, 19:03:20
balabol.1974, changed object description from 'СКАТ-П' to 'СКАТ-П [93км 800м]'.
07 June 2021, 13:00:04
Никого. И стоять негде. Стояли по центру, на разделительно. Теперь если что только на обочине.
12 July 2022, 14:14:08
Больше года никого.
12 July 2022, 18:59:58
Прошу помочь обнулить в этой точке тоже, как в соседней.
12 July 2022, 14:15:14
см. выше -1
12 July 2022, 14:15:17
см. выше -1
12 July 2022, 19:12:54
не актуально -1
12 July 2022, 19:12:56
не актуально -1
12 July 2022, 19:12:58
не актуально -1
13 July 2022, 07:08:28
Нет парковки -1
13 July 2022, 07:08:32
Нет парковки -1
13 July 2022, 07:08:35
Нет парковки -1
