05 October 2026, 09:22:59
For the past 24 hours: 55 objects added, 50 objects edited, 13 objects removed.
08 August 2019, 09:16:49
08 August 2019, 09:18:31
6
08 August 2019, 09:44:31
Это как это так надо было умудриться сделать фото?! Плюс за работу!
09 August 2019, 05:31:19
Спасибо, плюс к карме.
08 August 2019, 13:50:34
Zenduri, changed control area.
Zenduri, changed camera model.
08 August 2019, 13:51:34
Добавил контроль в тыл
30 August 2019, 16:25:17
01 September 2019, 17:45:03
Плюс
01 September 2019, 17:42:36
01 September 2019, 17:42:39
01 September 2019, 17:42:43
01 September 2019, 17:43:24
Zenduri, changed object description from 'АвтоУраган-ВСМ-2 (тыл)' to 'АвтоУраган-ВСМ-2 (тыл) [34км 901м]'.
02 September 2019, 08:32:04
"[font="Segoe UI", "Helvetica Neue", "Apple Color Emoji", "Segoe UI Emoji", Helvetica, Arial, sans-serif]Постановление по видеофиксации №1881015019083047*** от 30.08.2019 МОСКОВСКАЯ ОБЛ. А/Д М-11 "САНКТ-ПЕТЕРБУРГ - МОСКВА", 34КМ 901М, В МОСКВУ" [/font] фотки почему-то не приходят с этим штрафом. уже несколько там было - все без фоток абсолютно
04 September 2019, 05:12:14
Yald, changed control area.
Yald, changed object type from   to  Static speed camera Static speed camera.
04 September 2019, 05:12:26
Yald, changed object type from  Static speed camera Static speed camera to   .
04 September 2019, 05:12:50
Убрал "хвост" (см. общую карту).
08 September 2019, 10:13:48
08 September 2019, 10:14:02
23 September 2019, 18:44:07
03 November 2019, 20:29:40
07 November 2019, 11:08:03
есть фото +1
09 April 2020, 21:56:57
25 June 2020, 19:12:32
01 August 2020, 22:11:48
23 October 2020, 19:24:16
23 November 2020, 21:04:20
На мой взгляд, на такой трассе 500 метров- маловато, даже для контроля в спину.. Минимум метров 650, а лучше 700-800..
14 December 2020, 17:49:53
Завышен -1
25 December 2020, 09:40:31
Hyundi505, changed object notification distance from 500 to 650.
26 December 2020, 16:30:08
10 January 2021, 21:14:40
valur111, changed object notification distance from 650 to 750.
10 February 2021, 12:41:22
26 February 2021, 10:31:26
Смотрю в этом месте прям рассыпали камер, которые в зад бьют. Чтобы подавились, упыри. [img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAqoAAAKzCAYAAADWXC85AAAgAElEQVR4nOy951dVabY9/Ptr7q/H6NtVne6t7qpqu0strWDOCoJIToLkHCVIjoLknJOASBIkZ0GCioIBc87Zqvl uO9cvc7Wfu/X90M7xhkSzjmcs8/e65nPXHPO9X/w73///vfvf// 9 9///7373///vfvf// 9//Df/ HXywtLcHe3h4HDhyAnZ0drK2tYWFhAXNzc zfvx979 7Fzp07sX37dmzbtg1btmzB1q1bsXPnTuzYsQN79uzBgQMHYGVlBXNzc zduxd79 7Frl27sG3bNuzatQtmZmYwMzPDvn37sH//fhw8eBCOjo44dOgQPDw84OXlhZCQEISFheHIkSM4evQoEhMTkZaWhuPHjyM5ORm5ubkoKytDZWUlKisrUVpaioKCAhQVFaGsrAxVVVWora1FbW0tKisrUVJSgmPHjiE9PR3FxcUoLS1FRUUFGhsb0dvbi9nZWczNzeHUqVMoLi5GcXExKioqkJubiyNHjiAoKAg5OTkYGhrC1atXcffuXaysrGBubg4DAwNoa2tDY2Mjmpub0d7ejvb2djQ3N6OpqQmVlZXIyMiQ95CRkYGsrCzk5OSgsrISNTU1SExMhJOTE2xsbBAQEICysjKMjY3h3LlzGBgYQGVlJdLT0xEdHY3Y2FgkJCQgLCwMrq6u2LNnDzZt2oS1a9di9erV PHHH2FmZgY3Nzf4 voiJCQE0dHRiI6ORmBgIFxdXXHw4EHs3r0b69evx9dff42//vWv Nvf/oZVq1Zh1apV2LBhA2xtbREYGIiUlBQUFhaitLQUOTk5SE1NRWJiIlJSUpCUlIT4 HikpKQgLy9Pjn1hYSHS0tKQmpqKnJwcFB
26 February 2021, 10:33:12
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAqoAAAKzCAYAAADWXC85AAAgAElEQVR4nOy951dVabY9/Ptr7q/H6NtVne6t7qpqu0strWDOCoJIToLkHCVIjoLknJOASBIkZ0GCioIBc87Zqvl uO9cvc7Wfu/X90M7xhkSzjmcs8/e65nPXHPO9X/w73///vfvf// 9 9///7373///vfvf// 9//Df/ HXywtLcHe3h4HDhyAnZ0drK2tYWFhAXNzc zfvx979 7Fzp07sX37dmzbtg1btmzB1q1bsXPnTuzYsQN79uzBgQMHYGVlBXNzc zduxd79 7Frl27sG3bNuzatQtmZmYwMzPDvn37sH//fhw8eBCOjo44dOgQPDw84OXlhZCQEISFheHIkSM4evQoEhMTkZaWhuPHjyM5ORm5ubkoKytDZWUlKisrUVpaioKCAhQVFaGsrAxVVVWora1FbW0tKisrUVJSgmPHjiE9PR3FxcUoLS1FRUUFGhsb0dvbi9nZWczNzeHUqVMoLi5GcXExKioqkJubiyNHjiAoKAg5OTkYGhrC1atXcffuXaysrGBubg4DAwNoa2tDY2Mjmpub0d7ejvb2djQ3N6OpqQmVlZXIyMiQ95CRkYGsrCzk5OSgsrISNTU1SExMhJOTE2xsbBAQEICysjKMjY3h3LlzGBgYQGVlJdLT0xEdHY3Y2FgkJCQgLCwMrq6u2LNnDzZt2oS1a9di9erV PHHH2FmZgY3Nzf4 voiJCQE0dHRiI6ORmBgIFxdXXHw4EHs3r0b69evx9dff42//vWv Nvf/oZVq1Zh1apV2LBhA2xtbREYGIiUlBQUFhaitLQUOTk5SE1NRWJiIlJSUpCUlIT4 HikpKQgLy9Pjn1hYSHS0tKQmpqKnJwcFBYWIikpCQkJCUhPT0dubi5ycnIQGxuLI0eOICsrC1VVVWhvb8fo6CgmJibQ09ODkpISpKamIikpCenp6Th69Ci8vLzkW
26 February 2021, 10:34:33
Картинки не грузятся, если копипастой вставлять.
16 October 2021, 07:24:45
16 October 2021, 07:25:17
23 October 2021, 16:17:32
07 October 2022, 07:33:17
07 October 2022, 07:33:50
27 January 2023, 13:48:47
balabol.1974, changed object description from 'АвтоУраган-ВСМ-2 (тыл) [34км 901м]' to 'демонтаж'.
27 January 2023, 13:49:12
ДЕМОНТАЖ -1
27 January 2023, 13:49:16
ДЕМОНТАЖ -1
27 January 2023, 13:49:19
ДЕМОНТАЖ -1
27 January 2023, 13:59:54
27 January 2023, 13:59:58
27 January 2023, 14:00:01
27 January 2023, 14:18:43
выше -1
27 January 2023, 14:18:47
выше -1
27 January 2023, 14:18:51
выше -1
27 January 2023, 14:19:20
kroxan, changed control area.
kroxan, changed object notification distance from 750 to 100.
16 May 2024, 12:43:36
