22 October 2026, 20:18:56
29 June 2012, 06:28:55
29 June 2012, 06:54:50
mikhs, changed object latitude from 37.672959 to 37.672632
mikhs, changed object longitude from 55.594765 to 55.594756
29 June 2012, 06:55:21
Что из себя представляет ? Видеоблок от Стрелки ?
29 June 2012, 12:45:56
один блок, внизу глазок камеры, сверху как стрелка
29 June 2012, 15:23:03
леха150, changed object notification distance from 263 to 300.
леха150, changed object description from 'камера на полосе общественного транспорта' to 'Стрелка-СТ,контроль полосы ОТ'.
29 June 2012, 15:27:19
полоса в этом месте есть,вот такого плана камера?
02 July 2012, 06:40:07
Камера такая
03 July 2012, 04:24:09
1,5км от поста ГАИ +1
23 July 2012, 06:01:10
А почему он еще и за скорость кричит? Нету в нём измерителя...
И все по Липетской от кольца так...
07 August 2012, 10:45:20
Johannes, changed object latitude from 37.672632 to 37.672460
Johannes, changed object longitude from 55.594756 to 55.595300
Johannes, changed object description from 'Стрелка-СТ,контроль полосы ОТ' to 'Стрелка-СТ, контроль полосы ОТ'.
07 August 2012, 10:45:58
Отредактировал по снятым координатам.
25 March 2015, 22:05:07
28 October 2015, 09:31:20
Полоса ОТ.
Полоса ОТ.
28 October 2015, 09:33:05
Пардон, накладка!
28 October 2015, 09:33:08
Полоса ОТ.
Полоса ОТ.
28 October 2015, 09:34:11
НИЖЕ ПРАВИЛЬНОЕ ФОТО:
28 October 2015, 09:34:38
Полоса ОТ.
Полоса ОТ.
09 February 2016, 18:36:22
Пусть такое, чем никакого:
09 February 2016, 18:36:38
09 February 2016, 18:37:28
Полоса ОТ.
Полоса ОТ.
08 June 2016, 09:33:27
08 June 2016, 09:34:47
29 March 2017, 16:09:37
, changed object description from 'Стрелка-СТ, контроль полосы ОТ' to 'Стрелка-СТ'.
29 September 2017, 08:01:29
29 September 2017, 08:01:39
26 October 2017, 21:17:56
26 October 2017, 21:18:06
08 November 2017, 12:39:48
08 November 2017, 12:39:58
28 May 2018, 20:49:53
28 May 2018, 20:50:13
Фоторепортаж
05 June 2018, 17:19:07
26 August 2018, 23:17:58
27 September 2018, 12:06:24
Мото. -1
28 September 2018, 14:50:19
Ноль для мото -1
22 November 2018, 09:04:39
31 March 2020, 13:11:54
19 July 2021, 06:10:33
Повесили стрелку 360-С!
19 July 2021, 07:14:39
Там замена камеры?
19 July 2021, 12:38:23
Да, новая купольная стоит
19 July 2021, 07:16:32
Да, позже сделаю фото!
19 July 2021, 07:25:15
balabol.1974, changed object description from 'Стрелка-СТ' to 'Стрелка-360-С'.
19 July 2021, 07:26:18
замена до подтверждения -1
19 July 2021, 07:26:22
19 July 2021, 07:26:34
актуально +1
20 July 2021, 12:06:40
20 July 2021, 12:18:58
20 July 2021, 12:19:10
20 July 2021, 15:46:18
26 July 2021, 09:38:38
operatornew, changed object latitude from 37.672460 to 37.672766
operatornew, changed object longitude from 55.595300 to 55.594122
operatornew, changed warning direction from 172 to 169.
operatornew, changed object notification distance from 300 to 317.
operatornew, changed object view angle from 15 to 10.
26 July 2021, 12:19:41
balabol.1974, changed object latitude from 37.672766 to 37.672737
balabol.1974, changed object longitude from 55.594122 to 55.594211
balabol.1974, changed warning direction from 169 to 171.
balabol.1974, changed object notification distance from 317 to 300.
balabol.1974, changed object view angle from 10 to 15.
30 January 2022, 19:15:11
DarkMatter, changed control direction from Counter direction to Both directions.
08 January 2023, 21:36:53
Странно, с тех пор как повесили стрелку 360 ни одного подтвержденного штрафа.
10 April 2024, 10:59:39
Поменяли на новую Стрелку в лицо, 360 убрали. 10.04.2024.
10 April 2024, 11:00:59
, changed object description from 'Стрелка-360-С' to 'Стрелка-Плюс'.
11 April 2024, 12:16:42
15 April 2024, 09:34:49
, changed object description from 'Стрелка-Плюс' to 'Стрелка-М-В'.
27 June 2025, 12:32:05
02 March 2026, 03:20:03
02 March 2026, 03:20:28
Замена.
02 March 2026, 03:21:44
Изменил ограничение и прописал TTS.
27 March 2026, 04:38:04
Теперь её там физически нет
27 March 2026, 04:38:06
27 March 2026, 05:12:28
27 March 2026, 05:12:33
27 March 2026, 07:59:07
См.выше. Удалил -1
27 March 2026, 07:59:11
См.выше. Удалил -1
27 March 2026, 07:59:14
См.выше. Удалил -1
27 March 2026, 18:19:30
27 March 2026, 18:19:53
, changed object description from 'Стрелка-Плюс' to 'архив'.
