23 October 2026, 13:02:48
СКАТ-ПП в спину [80км 090м]
20 September 2020, 07:16:50
20 September 2020, 17:47:17
dronn1, changed speed limit from 0 to 40.
dronn1, changed warning direction from 248 to 249.
dronn1, changed object notification distance from 500 to 206.
dronn1, changed object view angle from 15 to 23.
dronn1, confirmed object added via Mapcam.info program
20 September 2020, 17:48:47
недавно установили
20 September 2020, 18:04:27
21 September 2020, 08:40:42
mihan11, changed object description from 'Объект добавлен 2020-09-13 05:49:37 с помощью MapcamDroid' to 'Статическая камера, измеряющая скорость'.
21 September 2020, 08:42:33
Похоже СКАТ-С.
21 September 2020, 09:35:22
Наверно . Её только недавно поставили . Там не далеко ставили иногда триноги
19 December 2020, 21:09:23
avi32, changed camera model.
19 December 2020, 21:11:33
avi32, changed warning direction type from Two directions to In a certain direction.
19 December 2020, 21:13:12
avi32, changed warning direction from 249 to 68.
20 December 2020, 03:05:26
20 December 2020, 03:06:03
semaa1, changed object description from 'Статическая камера, измеряющая скорость' to 'СКАТ-С'.
18 August 2021, 12:33:16
dronn1, changed object notification distance from 206 to 323.
18 August 2021, 12:34:21
dronn1, changed warning direction type from In a certain direction to Two directions.
18 August 2021, 16:26:24
Оповещение в попутном напрвлении избыточно,т.к. дублирует оповещение о контроле в спину.
dronn1, changed object notification distance from 323 to 271.
18 August 2021, 16:23:13
18 August 2021, 16:23:33
18 August 2021, 16:24:28
Survey_19, changed warning direction type from Two directions to In a certain direction.
Survey_19, changed object notification distance from 271 to 500.
Survey_19, changed object view angle from 23 to 25.
18 August 2022, 13:43:11
18 August 2022, 16:16:33
Timon34, changed object description from 'СКАТ-С' to 'СКАТ-ПП [80км 090м]'.
18 August 2022, 16:17:27
Подтверждено https://mapcam.info/forum/index.php?topic=2638.msg96406#msg96406 +1
18 August 2022, 16:17:34
Подтверждено +1
31 October 2022, 18:23:44
13 September 2023, 20:23:18
13 September 2023, 20:28:02
06 June 2024, 13:01:03
06 June 2024, 13:51:24
Перевернули? По снимкам с камер правильно было, насколько вижу.
06 June 2024, 14:05:24
да поменяли направление
06 June 2024, 13:03:31
06 June 2024, 13:13:40
, changed object description from 'СКАТ-ПП [80км 090м]' to 'СКАТ-ПП в спину [80км 090м]'.
06 June 2024, 14:14:39
См.выше +1
06 June 2024, 14:14:52
Завышенный рейтинг -1
24 June 2025, 15:24:48
