20 November 2026, 08:08:11
ПТКВ (рейтинг ноль!!!)
08 January 2018, 00:48:43
08 January 2018, 00:49:13
Primorets, switched object to test mode
08 January 2018, 00:49:54
До подтверждения опасности аналогичных комплексов.
08 January 2018, 00:56:08
С обратной стороны
С обратной стороны
15 January 2018, 21:15:41
Со вчера меняем данный тип камер и делаем им рейтинг ноль! Ссылка ниже! Могу помочь!
https://mapcam.info/speedcam/point.php?idx=1042376
16 January 2018, 06:29:23
Ок. Можете понизить рейтинг до 0 с возвратом кармы.
16 January 2018, 06:27:44
Primorets, changed object type from  Static speed camera Static speed camera to   .
Primorets, changed warning direction from 235 to 56.
Primorets, changed object notification distance from 299 to 200.
Primorets, changed object description from 'АвтоУраган-ВСМ' to 'ПКТВ (рейтинг ноль!!!)'.
16 January 2018, 06:28:45
Primorets, turned off test mode
16 January 2018, 06:35:02
см.выше + вернул. -1
25 January 2018, 15:09:20
Primorets, changed object description from 'ПКТВ (рейтинг ноль!!!)' to 'ПТКВ (рейтинг ноль!!!)'.
31 March 2018, 12:39:55
Primorets, changed object type from   to  Lane Control Camera Lane Control Camera.
31 March 2018, 12:40:15
Развернули.
06 June 2022, 10:28:08
balabol.1974, changed speed limit from 60 to 50.
balabol.1974, changed object notification distance from 200 to 100.
