22 October 2026, 10:43:53
Кордон-Темп
17 August 2017, 17:55:17
17 August 2017, 17:56:24
Dovos, changed object description from 'Кордон' to 'Кордон-Темп'.
17 August 2017, 17:57:09
Опять вернули сюда
04 March 2018, 14:15:56
Dovos, changed object description from 'Кордон-Темп' to 'Сняли'.
Dovos, switched object to test mode
09 April 2018, 22:45:03
Если КОРДОН-М 4  вернут на место - будет нужна парная точка "в спину"
09 April 2018, 22:46:28
для статистики
для статистики
30 May 2018, 17:53:14
Dovos, changed object description from 'Сняли' to 'Кордон-Темп'.
Dovos, turned off test mode
30 May 2018, 17:53:49
Опять повесили назад
10 August 2018, 20:00:08
Dovos, changed object latitude from 46.016439 to 46.015205
Dovos, changed object longitude from 51.596543 to 51.596933
25 August 2018, 05:06:00
25 August 2018, 05:06:23
25 August 2018, 05:08:05
17 November 2019, 12:28:51
Приветствую. Точка актуальна?
21 October 2020, 16:21:42
камеры год как нет -1
21 October 2020, 16:21:45
21 October 2020, 16:21:48
21 October 2020, 19:46:31
См выше -1
21 October 2020, 19:46:36
См выше -1
21 October 2020, 19:46:39
См выше -1
03 December 2020, 11:11:35
по просьбе -1
03 December 2020, 11:11:38
по просьбе -1
03 December 2020, 11:11:41
по просьбе -1
