22 October 2026, 08:13:57
Скат-ПП
Russian Federation > Кемеровская область
08 October 2015, 09:24:32
08 October 2015, 11:04:05
silandser, changed warning direction from 210 to 214.
08 October 2015, 11:07:40
2maxic, changed object description from 'Камера Арена,контроль скорости 60км/ч' to 'Арена. Контроль скорости 60км/ч'.
09 October 2015, 03:19:50
Hаwk, changed object latitude from 87.152985 to 87.152465
Hаwk, changed object longitude from 53.791294 to 53.790822
Hаwk, changed warning direction from 214 to 34.
09 October 2015, 03:20:22
поправил направление и место установки
24 September 2016, 07:48:56
работают.
для фильтра "от +2" +1
18 April 2018, 17:42:08
Не работает, штрафы с неё не приходят.
24 April 2018, 00:57:16
Работает. Точка актуальна.
18 August 2021, 15:32:23
miromonah, changed object description from 'Арена. Контроль скорости 60км/ч' to 'Скат-ПП'.
miromonah, changed camera model.
18 August 2021, 15:32:39
Актуализировал на 18.08.2021 по данным Дирекции автомобильных дорог Кузбасса
18 August 2021, 15:53:11
2maxic, changed object type from  Static speed camera Static speed camera to   .
2maxic, changed warning direction from 34 to 214.
2maxic, changed additional information (RU): \"
18 August 2021, 15:54:13
2maxic, changed control area.
18 August 2021, 15:59:25
17 October 2022, 06:24:27
MACK, changed control area.
MACK, changed speed limit from 60 to 40.
22 August 2023, 09:42:47
MACK, changed speed limit from 40 to 60.
05 April 2025, 09:54:55
Демонтаж
05 April 2025, 09:55:43
См. выше -1
05 April 2025, 09:55:48
См. выше -1
05 April 2025, 09:55:55
См. выше -1
05 April 2025, 10:10:33
Выше -1
05 April 2025, 10:10:36
Выше -1
05 April 2025, 10:10:38
Выше -1
05 April 2025, 10:17:26
05 April 2025, 10:17:37
05 April 2025, 10:17:41
05 April 2025, 10:17:45
05 April 2025, 10:18:15
