14 November 2026, 05:19:32
For the past 24 hours: 53 objects added, 104 objects edited, 36 objects removed.
КРИС-ПМ FP4224 (478км+460м)
14 July 2016, 09:13:38
14 July 2016, 09:16:03
Перед и за пешеходным переходом.
14 July 2016, 16:05:34
valur111, changed object longitude from 59.328722 to 59.328742
26 October 2016, 22:14:16
stroy82, changed object latitude from 39.990374 to 39.989746
stroy82, changed object longitude from 59.328742 to 59.328391
stroy82, changed warning direction type from Two directions to In a certain direction.
26 October 2016, 22:15:17
Уточнил, разделил на две.
07 December 2016, 20:11:06
Для чего разделили?
07 December 2016, 20:52:25
Дурацкий ответ. Как бы одна камера снимает встречно, а вторая попутно. Так заведено на проекте (пока это сломать не можем).
26 October 2016, 22:16:47
26 October 2016, 22:17:15
stroy82, changed object description from 'Пара КРИС-П в ящиках' to 'КРИС-П в ящике на опоре'.
31 October 2016, 18:31:03
31 October 2016, 18:31:40
Есть Крис! Исправно работает!
31 October 2016, 18:49:06
Трудится. +1
06 December 2016, 18:03:41
stroy82, changed object description from 'КРИС-П в ящике на опоре' to 'КРИС-П (478км+460м)'.
06 December 2016, 18:43:36
stroy82, changed control area.
stroy82, changed object type from  Static speed camera Static speed camera to   .
stroy82, changed warning direction from 40 to 220.
06 December 2016, 18:44:07
06 December 2016, 18:44:30
В Вологду.
21 May 2017, 14:11:05
23 July 2018, 07:54:50
Удалите, камер уже нет и знак 50 уже убрали, построили мост за места пешеходного перехода.
25 July 2018, 12:44:06
камеру перенесли подальше вот фото
25 July 2018, 12:46:47
Крис
Крис
25 July 2018, 16:59:34
Почему удалять, когда можно передвинуть.  Увас карма больше +5 и вы можете откорректировать точку сами.
30 July 2018, 01:13:41
edu, changed object latitude from 39.989746 to 39.992183
edu, changed object longitude from 59.328391 to 59.329677
30 July 2018, 01:14:02
edu, changed object notification distance from 500 to 300.
13 August 2018, 19:47:55
sademid51, changed control area.
22 August 2018, 03:00:45
едем в Вологду
едем в Вологду
08 December 2018, 06:46:52
NikAndr, changed object latitude from 39.992183 to 39.992085
NikAndr, changed object longitude from 59.329677 to 59.329727
NikAndr, changed control area.
NikAndr, changed object view angle from 15 to 20.
08 December 2018, 06:50:48
08 December 2018, 06:52:35
Ящик направлен в одну сторону, тренога на крыше машины - в другую сторону. Так что нужно этот объект объединить с этим, сделав его двухсторонним.
10 December 2018, 09:31:00
Где комментарий от тайного лица, отминусовашего это сообщение? Постеснялся?
14 December 2018, 08:37:57
Поскольку автор минуса стесняется признавать свои ошибки и исправлять их, пишу сам.
Автор параллельного объекта конкретно пишет, что его объект является дублем данного объекта.
Просмотрел свою видеозапись. Ящик, фотография которого приведена слева на столбе здесь,  и на эту фотографию ссылается автор дублирующей точки здесь - это тот же ящик, фотографию которого я привел здесь.
Если внимательно посмотреть все фотографии, то видно, что на них приведена информация о штрафах с обеих полос и в обе стороны.
Автору минуса почему-то взбрело в голову, что параллельный объект - эт
26 April 2019, 18:11:02
19 October 2019, 06:38:37
Измените скорость на 60. Знак 50 давно убран. Фото штрафа выше это подтверждает.
19 October 2019, 13:47:01
Изменил.
19 October 2019, 13:46:27
stroy82, changed speed limit from 50 to 60.
stroy82, changed object notification distance from 300 to 350.
29 July 2020, 11:17:25
NikAndr, changed object description from 'КРИС-П (478км+460м)' to 'КРИС-ПМ FP4224 (478км+460м)'.
NikAndr, changed camera model.
13 August 2020, 19:23:51
01.08.20: ящик был пустой. РД молчит.
13 August 2020, 19:23:59
13 August 2020, 19:26:01
Слева на столбе. Едем в Вологду.
20 July 2021, 08:09:24
сняли -1
20 July 2021, 08:10:03
20 July 2021, 10:34:19
03 August 2021, 05:22:51
Ставят дополнительно треногу за перекрёстком.
03 August 2021, 05:22:52
03 August 2021, 05:23:54
Доп. тренога +1
03 August 2021, 05:25:20
stroy82, changed additional information (RU): \"
08 February 2022, 16:55:01
сейчас тут камеры нет. убрали
04 July 2023, 19:31:25
сняли -1
28 September 2023, 20:40:30
см выше, демонтаж -1
28 September 2023, 20:40:35
28 September 2023, 20:40:38
