04 October 2026, 05:49:56
For the past 24 hours: 38 objects added, 28 objects edited, 5 objects removed.
Russian Federation > Липецкая область
28 April 2014, 13:49:03
23 February 2016, 05:01:40
xydryk, confirmed object added via Mapcam.info program
23 February 2016, 05:10:29
xydryk, changed object notification distance from 500 to 110.
23 February 2016, 05:11:28
Раритетная точка. 2 года в загашнике лежала. Отредактируйте только.
23 February 2016, 05:31:13
Подскажи, что  в ней не так?
23 February 2016, 05:32:05
Описание не забывайте менять
23 February 2016, 05:33:52
xydryk, changed warning direction from 216 to 212.
23 February 2016, 05:40:29
xydryk, changed object description from 'Объект добавлен с помощью программы MapcamDroid (off-line)' to 'Лежачий полицейский'.
23 February 2016, 06:07:02
sademid51, changed object latitude from 39.566360 to 39.566301
sademid51, changed object longitude from 52.594843 to 52.594863
23 February 2016, 06:08:00
Точки ставим по центру дороги по OSM карте при максимальном увеличении, даже если они на столбе сбоку или на углу дома.
23 February 2016, 07:01:42
Спасибо  за подсказку.
19 September 2019, 12:40:50
Отсутствует -1
19 September 2019, 12:40:54
Отсутствует -1
19 September 2019, 12:40:56
Отсутствует -1
19 September 2019, 12:41:14
Подробности здесь https://mapcam.info/forum/index.php?topic=1364.msg82540#msg82540
19 September 2019, 13:34:49
См. выше -1
19 September 2019, 13:34:54
См. выше -1
19 September 2019, 13:34:59
См. выше -1
19 September 2019, 13:35:42
feudor10, changed warning direction type from Two directions to In a certain direction.
feudor10, changed object notification distance from 110 to 100.
feudor10, changed object view angle from 15 to 10.
