20 November 2026, 08:58:20
22 September 2020, 08:34:51
22 September 2020, 08:35:43
sporting_, changed warning direction from 0 to 25.
22 September 2020, 08:36:02
sporting_, changed object notification distance from 500 to 150.
23 September 2020, 06:28:55
20 March 2021, 15:08:10
balabol.1974, changed object type from  Stop control camera Stop control camera to  Static speed camera Static speed camera.
20 March 2021, 15:08:23
20 March 2021, 15:10:28
актуально +1
20 March 2021, 15:10:31
актуально +1
20 March 2021, 15:15:39
20 March 2021, 15:24:21
balabol.1974, changed warning direction from 25 to 22.
balabol.1974, changed object notification distance from 150 to 350.
balabol.1974, changed object view angle from 15 to 25.
20 March 2021, 15:26:46
Напишите какая модель камеры указана в постановлении?
20 March 2021, 15:46:52
Письма нет ещё ,  гос услугах не написано модель( какие последний год ставят по городу) .
20 March 2021, 18:46:40
balabol.1974, changed object description from 'Стрелка-М-П' to 'Стрелка-М-В'.
06 April 2021, 11:44:54
28 May 2021, 07:15:49
28 May 2021, 07:18:24
Штраф пришёл больше, чем через месяц.
15 August 2024, 08:09:03
06 June 2025, 14:21:43
, changed object description from 'Стрелка-М-В' to 'МУЛЯЖ! Стрелка-М-В (рейтинг ноль)'.
06 June 2025, 14:21:55
нет в базе -1
06 June 2025, 14:21:57
нет в базе -1
06 June 2025, 14:36:01
выше -1
06 June 2025, 14:36:05
выше -1
06 June 2025, 14:36:48
, changed warning direction from 22 to 25.
, changed object notification distance from 350 to 150.
, changed object view angle from 25 to 15.
22 September 2025, 08:08:21
22 September 2025, 08:08:45
Может стоит вернуть?
22 September 2025, 13:01:18
Старая информация. Из последней базы удалена. Пока висит - муляж, а демонтаж - дело времени. Такого отключенного добра ещё более тридцати штук.
24 September 2025, 19:02:24
, changed object notification distance from 150 to 300.
, changed object description from 'МУЛЯЖ! Стрелка-М-В (рейтинг ноль)' to 'Стрелка-Плюс'.
24 September 2025, 19:02:37
замена +1
24 September 2025, 19:02:41
замена +1
24 September 2025, 19:08:06
24 September 2025, 19:08:29
Заполнил TTS.
24 September 2025, 19:09:29
, changed object notification distance from 300 to 350.
01 December 2025, 18:24:26
ДЕМОНТАЖ -1
01 December 2025, 18:24:29
ДЕМОНТАЖ -1
01 December 2025, 18:24:32
ДЕМОНТАЖ -1
01 December 2025, 18:25:12
, changed object description from 'Стрелка-Плюс' to 'архив'.
01 December 2025, 18:39:24
выше -1
01 December 2025, 18:39:27
выше -1
