05 November 2026, 07:13:58
For the past 24 hours: 73 objects added, 87 objects edited, 18 objects removed.
Дядин
14 April 2012, 14:23:52
27 July 2015, 13:08:40
Narart, changed object latitude from 40.524936 to 40.524780
Narart, changed object longitude from 49.834117 to 49.834698
Narart, changed warning direction from 345 to 342.
24 August 2016, 11:25:03
silandser, changed object latitude from 40.524780 to 40.524877
silandser, changed object longitude from 49.834698 to 49.834705
silandser, changed object view angle from 15 to 45.
25 August 2016, 09:38:29
21 May 2023, 05:11:44
Пользователи сообщают что НП обозначен табличной на синем фоне?! Может кто то проезжал на данном участке дороги? А здесь обсуждение: https://mapcam.info/forum/index.php?topic=5.msg97935#msg97935
15 June 2023, 18:56:12
15 June 2023, 18:56:32
См. Выше -1
15 June 2023, 18:56:35
См. Выше -1
15 June 2023, 18:56:37
См. Выше -1
15 June 2023, 19:29:14
silandser, changed object view angle from 45 to 10.
15 June 2023, 19:29:34
См.выше. Удалил. -1
15 June 2023, 19:29:36
См.выше. Удалил. -1
15 June 2023, 19:29:38
См.выше. Удалил. -1
