22 October 2026, 10:44:31
Арена
04 May 2016, 20:34:47
04 May 2016, 20:38:49
10 July 2016, 09:58:15
10 July 2016, 09:58:30
10 July 2016, 16:55:07
Шикарный снимок.
10 July 2016, 16:56:25
stroy82, changed object description from '`Арена` 1002 км.' to 'Арена 1002 км.'.
16 July 2016, 16:26:38
16.7.16 в 13-35 Арены в обе стороны
28 July 2016, 12:47:51
28.07.2016 Арена-П в обе стороны +1
08 January 2017, 14:07:39
С противоположного направления
08 January 2017, 14:08:52
15 April 2017, 08:51:47
03 January 2018, 21:51:40
03 January 2018, 21:52:09
05 January 2018, 08:30:32
02 March 2018, 02:26:02
Это к противоположной точке.
Тут вниз, а там вверх
30 January 2018, 11:30:25
300118 Арены оба направления
01 March 2018, 19:01:48
прохоров, changed object notification distance from 450 to 500.
прохоров, changed object description from 'Арена 1002 км.' to 'Арена (1002 км 200м)'.
прохоров, changed warning start time from 0 to 5.
21 April 2018, 06:15:42
21.04.18 в районе 9 утра Арены в обе стороны
24 April 2018, 10:01:52
uDAV163, changed object description from 'Арена (1002 км 200м)' to 'Арена (1002 км+200м)'.
10 June 2018, 04:16:39
uDAV163, changed warning start time from 5 to 0.
uDAV163, changed warning end time from 23 to 24.
10 September 2018, 14:03:56
uDAV163, changed speed limit from 90 to 70.
12 August 2019, 20:11:16
radiorecordperm, changed warning direction from 277 to 276.
radiorecordperm, changed object notification distance from 500 to 900.
12 August 2019, 20:12:31
9.06.19 стояли обе здесь: Координаты: 49.920025, 53.512773 Добавил дистанцию, чтобы здорово не двигать
13 August 2019, 04:22:24
uDAV163, changed object description from 'Арена (1002 км+200м)' to 'Арена'.
04 March 2021, 22:15:12
Не актуальны -1
04 March 2021, 23:13:26
См. выше -1
04 March 2021, 23:13:30
См. выше -1
04 March 2021, 23:13:33
См. выше -1
05 March 2021, 02:10:27
См выше -1
05 March 2021, 02:10:31
См выше -1
05 March 2021, 02:10:34
См выше -1
05 March 2021, 03:44:37
См. выше. -1
05 March 2021, 03:44:41
См. выше. -1
05 March 2021, 03:44:44
См. выше. -1
