23 October 2026, 10:33:23
For the past 24 hours: 39 objects added, 77 objects edited, 9 objects removed.
Стрелка-Плюс
27 November 2018, 12:14:10
27 November 2018, 12:16:57
4
27 November 2018, 13:14:13
27 November 2018, 13:15:02
Yald, changed warning direction from 289 to 294.
Yald, changed object view angle from 25 to 15.
Yald, changed camera model.
27 November 2018, 13:16:36
28 November 2018, 03:42:35
, changed object latitude from 37.436322 to 37.436340
, changed object longitude from 55.749144 to 55.749176
, changed warning direction from 294 to 281.
, changed object view angle from 15 to 75.
28 November 2018, 03:44:02
Пусть лучше фонит на дублёре, чем предупреждает с запаздыванием поток на основном ходу.
28 November 2018, 06:09:25
Если контроль скорости подтвердиться, тогда лучше будет добавить дополнительную точку.
05 December 2018, 13:35:44
Муляж. -1
05 December 2018, 13:35:47
Муляж. -1
05 December 2018, 13:36:07
, changed object description from 'Стрелка-М-Р' to 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)'.
05 December 2018, 20:37:20
, changed object notification distance from 350 to 300.
04 March 2019, 07:46:44
shtirlizr, changed object latitude from 37.436340 to 37.436966
04 March 2019, 07:48:31
Выставил по GPS регистратора. предупреждение стояло на пару столбов ближе к Рублевке
shtirlizr, changed object longitude from 55.749176 to 55.748923
04 March 2019, 09:06:38
maykl3011, changed object latitude from 37.436966 to 37.437045
maykl3011, changed object longitude from 55.748923 to 55.749057
maykl3011, changed warning direction from 281 to 289.
maykl3011, changed object view angle from 75 to 15.
04 March 2019, 09:07:57
Поставил на дорогу, угла в 15 для муляжа более чем достаточно.
25 November 2020, 14:09:22
25 November 2020, 14:10:32
Ау, changed object type from  Static speed camera Static speed camera to  Lane Control Camera Lane Control Camera.
Ау, changed object description from 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)' to 'Камера контроля полосы движения'.
25 November 2020, 14:11:07
25 November 2020, 14:11:11
25 November 2020, 14:14:42
DarkMatter, changed object description from 'Камера контроля полосы движения' to 'Стрелка-М-П'.
19 March 2021, 12:05:19
19 March 2021, 12:05:51
19 March 2021, 12:05:56
19 March 2021, 12:17:24
19 March 2021, 12:18:32
daniyar.sariev, changed object type from  Lane Control Camera Lane Control Camera to  Traffic control complex Traffic control complex.
19 March 2021, 12:19:19
19 March 2021, 12:19:54
Еще одна МП стала скорость фиксировать
19 March 2021, 17:47:34
растягивают удовольствие ) сначала типа муляжи, потом разметка... вот и до скорости добрались. хотя по докам всё умела.
19 March 2021, 12:40:23
maykl3011, changed object latitude from 37.437045 to 37.437023
maykl3011, changed object longitude from 55.749057 to 55.748983
maykl3011, changed warning direction from 289 to 288.
maykl3011, changed object notification distance from 300 to 350.
maykl3011, changed object view angle from 15 to 25.
19 March 2021, 12:44:33
balabol.1974, changed object latitude from 37.437022 to 37.437617
balabol.1974, changed object longitude from 55.748983 to 55.748811
balabol.1974, changed warning direction from 288 to 296.
19 March 2021, 13:17:13
Так с другой стороны моста цеплять будет, там тоже съезд. Лучше было бы, в доп.инфе указать "на мосту".
balabol.1974, changed object view angle from 25 to 15.
19 March 2021, 12:51:14
19 March 2021, 13:42:56
20 March 2021, 19:36:17
balabol.1974, changed object description from 'Стрелка-М-П' to 'Стрелка-М-В'.
21 March 2021, 05:21:40
08 June 2021, 17:33:03
09 August 2021, 14:02:02
09 August 2021, 14:02:44
09 August 2021, 14:03:30
Завышает скорость. В моем случае это было   6км/ч. Предлагаю изменить в параметрах скоростной режим на "50" км/ч.
28 September 2021, 20:26:27
30 January 2022, 11:00:27
18 November 2022, 07:48:24
18 November 2022, 07:48:40
Камера стала врать не по детски о скорости. Ехал со скоростью не выше 72 км/ч, пришел штраф аж на 87 км/ч.
04 September 2025, 09:05:40
02 December 2025, 04:42:36
, changed object latitude from 37.437618 to 37.437744
, changed object longitude from 55.748811 to 55.748886
, changed warning direction from 296 to 289.
02 December 2025, 04:43:30
Замена.
02 December 2025, 04:43:50
до штрафа -1
02 December 2025, 04:43:54
до штрафа -1
02 December 2025, 04:45:06
21 January 2026, 21:02:32
21 January 2026, 21:02:58
21 January 2026, 21:03:02
