23 October 2026, 05:52:36
Стрелка-СТ-М [21км]
05 October 2019, 10:07:20
05 October 2019, 10:11:03
silandser, changed object type from   to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
silandser, changed speed limit from 30 to 100.
silandser, changed speed limit from 0 to 100.
silandser, changed warning direction from 46 to 45.
silandser, changed object notification distance from 500 to 700.
silandser, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Стрелка-М'.
silandser, confirmed object added via Mapcam.info program
05 October 2019, 10:11:13
07 October 2019, 08:45:03
07 October 2019, 08:49:20
Почему-то криво загрузилась. Этого жирафа каждый день наблюдаю.
07 October 2019, 09:44:32
Спасибо
07 October 2019, 09:58:00
4 октября утром стоял
11 November 2019, 15:57:40
13 December 2019, 09:58:23
29 December 2019, 11:24:12
12 January 2020, 21:06:51
20 January 2020, 20:01:39
05 February 2020, 13:03:22
Подтверждено 2020-02-02 12:31:12 (UTC±00:00)
     Вероятность: 70 %  (Частота за прошлый месяц)
09 February 2020, 10:02:06
09 February 2020, 10:02:24
05/02/2020 в 13.30
24 February 2020, 22:22:23
06 March 2020, 19:27:25
Подтверждено 2020-03-06 07:30:44 (UTC±00:00)
     Достоверность: 5 (Коэффициент достоверности)
     Вероятность: 61 %  (Частота за прошлый месяц)
09 May 2020, 14:55:57
14 September 2020, 19:39:04
14 September 2020, 19:39:38
Регулярно на месте
23 September 2020, 15:30:24
27 October 2020, 16:41:31
23 May 2021, 20:57:06
23 May 2021, 20:57:40
Давно не было и вот снова появилась засада
23 May 2021, 21:22:42
DarkMatter, changed object description from 'Стрелка-М' to 'Стрелка-СТ-М'.
19 June 2021, 08:50:37
06 October 2022, 05:41:22
05 June 2023, 11:51:15
14 August 2023, 10:45:08
13.08.2023 г. работал жираф
25 September 2023, 08:39:52
24.09.2023 г. работал жираф
07 November 2024, 14:12:20
НЕТ В БАЗЕ -1
07 November 2024, 14:12:22
НЕТ В БАЗЕ -1
07 November 2024, 14:12:24
НЕТ В БАЗЕ -1
07 November 2024, 17:24:17
выше -1
07 November 2024, 17:24:20
выше -1
11 November 2024, 16:52:26
, changed object description from 'Стрелка-СТ-М' to 'архив'.
11 November 2024, 20:45:40
12 November 2024, 14:11:14
, changed object latitude from 37.770677 to 37.770691
, changed object longitude from 55.611500 to 55.611541
, changed object type from  Other danger Other danger to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
, changed object notification distance from 100 to 600.
, changed object description from 'архив' to 'Стрелка-СТ-М [21км]'.
12 November 2024, 14:11:48
возврат тест неактуален +1
12 November 2024, 14:11:51
12 November 2024, 14:11:54
12 November 2024, 14:16:16
Бурная деятельность. Буря в стакане
12 November 2024, 14:19:22
Нет взрыв мозга. Там Стрелка-СТ-М. Могу сделать новую засаду! Легко.
12 November 2024, 14:21:47
Я про другое
12 November 2024, 14:25:54
Снимите тест, этот адрес снова актуален от 12.11.2024. Всё ок забыли.))
12 November 2024, 15:26:02
выше +1
12 November 2024, 15:26:05
выше +1
12 November 2024, 15:26:08
выше +1
12 November 2024, 15:30:18
12 November 2024, 15:34:09
Камера есть в базе. Номер в списке 3253.
Координаты - 55.611606  37.770595
12 November 2024, 15:40:56
, turned off test mode
01 July 2026, 12:54:26
давно без подтверждений -1
01 July 2026, 12:54:30
