22 October 2026, 03:52:10
Статическая камера [480км 800м ]
08 December 2019, 12:26:28
08 December 2019, 13:22:46
14 December 2019, 13:17:51
silandser, changed object notification distance from 500 to 700.
silandser, changed object description from 'КОРДОН' to 'КОРДОН-М 4'.
14 December 2019, 13:19:42
silandser, changed object latitude from 39.221693 to 39.221683
silandser, changed object longitude from 51.943779 to 51.943549
silandser, changed warning direction from 3 to 2.
silandser, changed object view angle from 20 to 25.
14 December 2019, 13:20:52
14 December 2019, 13:21:10
Пока есть только ночное фото
14 December 2019, 21:25:11
26 January 2020, 16:12:06
setpiton, changed object description from 'КОРДОН-М 4' to 'КОРДОН-М 4 [480км 900м]'.
26 January 2020, 16:14:07
История точки.
09 April 2020, 20:08:10
s123, switched object to test mode
09 April 2020, 20:09:09
Сняли. Пока в тест перевел.
03 August 2020, 14:47:36
06 September 2020, 21:00:34
пока висела снимала спереди -1
26 December 2020, 21:06:03
silandser, changed object latitude from 39.221683 to 39.221863
silandser, changed object longitude from 51.943549 to 51.944835
silandser, changed object description from 'КОРДОН-М 4 [480км 900м]' to 'АвтоУраган'.
26 December 2020, 21:06:46
26 December 2020, 21:07:48
Замер по GPS  https://mapcam.info/speedcam/point.php?idm=AAPzgAPioB2
26 December 2020, 21:07:21
Просьба к автору вывести точку из ТЕСТА. Спасибо.
31 December 2020, 08:19:29
s123, changed object latitude from 39.221863 to 39.221801
s123, changed object longitude from 51.944835 to 51.944939
s123, turned off test mode
31 December 2020, 13:34:11
s123, changed object latitude from 39.221801 to 39.221767
s123, changed object longitude from 51.944939 to 51.944622
31 December 2020, 13:36:40
10 April 2021, 11:42:00
setpiton, changed object description from 'АвтоУраган' to 'Стрелка-Плюс-мини [480км 800м ]'.
01 November 2021, 19:18:51
Камеру сняли. Весь крепеж на месте.
25 November 2021, 20:10:00
Камеру вернули на место
25 November 2021, 20:10:01
14 July 2022, 06:44:28
14 July 2022, 06:44:39
фото штрафа +1
14 July 2022, 06:44:42
фото штрафа +1
07 August 2022, 05:51:48
21 February 2023, 07:10:50
silandser, changed object description from 'Стрелка-Плюс-мини [480км 800м ]' to 'Лидер-С [480км 800м ]'.
30 May 2023, 12:40:16
silandser, changed speed limit from 90 to 50.
silandser, changed speed limit from 70 to 50.
silandser, changed object notification distance from 700 to 500.
silandser, changed object description from 'Лидер-С [480км 800м ]' to 'КРИС-С [480км 800м ]'.
30 May 2023, 12:40:42
silandser, changed object description from 'КРИС-С [480км 800м ]' to 'Муляж. КРИС-С [480км 800м ]'.
30 May 2023, 12:41:01
Муляж. -1
30 May 2023, 12:41:04
Муляж. -1
30 May 2023, 12:49:56
30 May 2023, 12:54:12
До 0 -1
30 May 2023, 12:54:17
До 0 -1
10 May 2024, 12:56:34
, changed speed limit from 50 to 90.
, changed speed limit from 50 to 70.
, changed object notification distance from 500 to 800.
, changed object view angle from 25 to 35.
, changed object description from 'Муляж. КРИС-С [480км 800м ]' to 'Статическая камера [480км 800м ]'.
10 May 2024, 12:56:46
Актуализация +1
10 May 2024, 12:56:49
Актуализация +1
10 May 2024, 12:57:11
16 September 2024, 13:16:30
В конце августа 2024 г. полный демонтаж
05 November 2024, 11:00:12
На 02.11.2024 г. полный демонтаж.
05 November 2024, 11:00:23
Полный демонтаж -1
05 November 2024, 11:00:25
Полный демонтаж -1
05 November 2024, 11:00:28
Полный демонтаж -1
05 November 2024, 18:05:55
См выше.Демонтаж.Удалил -1
05 November 2024, 18:05:57
05 November 2024, 18:06:08
, changed object notification distance from 800 to 100.
, changed object view angle from 35 to 10.
