22 October 2026, 08:14:00
демонтаж
12 May 2016, 10:53:13
12 May 2016, 10:55:03
myagtin, changed object latitude from 38.627297 to 38.627930
myagtin, changed object notification distance from 203 to 135.
myagtin, changed object view angle from 15 to 36.
12 May 2016, 11:08:45
DiK57, changed object view angle from 36 to 20.
12 May 2016, 12:07:19
Elen, changed object description from 'Знак - ограничение скорости' to 'Знак ограничения скорости'.
15 March 2018, 16:57:42
, changed object latitude from 38.627930 to 38.633691
, changed object longitude from 55.782519 to 55.782628
, changed object type from  Speed limit sign Speed limit sign to   .
, changed warning direction from 270 to 88.
, changed object notification distance from 135 to 300.
, changed object description from 'Знак ограничения скорости' to 'АвтоУраган-ВСМ-2 (тыл)'.
15 March 2018, 16:59:10
Трансформировано в парную точку к смонтированному по соседству стационару.
15 March 2018, 18:14:56
, changed object latitude from 38.633691 to 38.633621
, changed object longitude from 55.782628 to 55.782655
, changed warning direction from 88 to 268.
15 March 2018, 18:24:33
Автор! Так правильно сейчас?
15 March 2018, 18:26:15
Правильно , ограничение скорости только 50 с обеих сторон
15 March 2018, 18:30:40
Данные предупреждения настроены на 50 км/ч !
15 March 2018, 19:37:44
, changed warning direction from 268 to 88.
15 March 2018, 19:38:19
Вернул как было!
02 April 2018, 18:59:07
22 June 2018, 19:31:10
09 February 2021, 13:10:49
Ashkrmane, changed object description from 'АвтоУраган-ВСМ-2 (тыл)' to 'АвтоУраган-ВСМ-2 (тыл) [1км 060м]'.
09 February 2021, 13:11:01
09 February 2021, 13:11:03
09 February 2021, 13:11:06
09 February 2021, 13:11:18
01 September 2021, 22:09:20
zhuk668, changed control area.
zhuk668, changed object type from   to  Other danger Other danger.
zhuk668, changed object description from 'АвтоУраган-ВСМ-2 (тыл) [1км 060м]' to 'Муляж'.
zhuk668, changed camera model.
zhuk668, changed additional information (RU): \"
01 September 2021, 22:09:46
Заменили на муляж -1
01 September 2021, 22:09:57
01 September 2021, 22:10:01
01 September 2021, 22:41:14
см. выше -1
01 September 2021, 22:41:16
см. выше -1
01 September 2021, 22:41:18
см. выше -1
02 September 2021, 03:35:43
выше -1
02 September 2021, 03:35:45
выше -1
02 September 2021, 03:35:48
выше -1
02 September 2021, 09:49:17
Муляжи в ноль.
02 September 2021, 09:50:13
abbc, changed object description from 'Муляж' to 'Муляж (Рейтинг 0)'.
02 September 2021, 09:53:42
Извините, был не прав
02 September 2021, 09:54:14
abbc, changed object description from 'Муляж (Рейтинг 0)' to 'Муляж '.
03 September 2021, 08:52:42
balabol.1974, changed object latitude from 38.633621 to 38.633403
balabol.1974, changed object longitude from 55.782655 to 55.782626
12 March 2023, 22:37:46
007MCD, changed object view angle from 20 to 10.
007MCD, changed object description from 'Муляж ' to 'демонтаж'.
