23 October 2026, 05:54:03
Стрелка-М [25км 940м]
07 October 2019, 15:04:33
07 October 2019, 15:08:29
Фото не могу пока добавить, шнура от регистратора нет
07 October 2019, 17:43:34
serezhka, changed object latitude from 37.351514 to 37.351523
serezhka, changed object longitude from 55.608390 to 55.608399
serezhka, changed warning direction from 65 to 72.
serezhka, changed object view angle from 25 to 15.
07 October 2019, 17:44:21
Скорость и так будет проговаривать
08 October 2019, 07:19:40
aleksei13, changed warning direction from 72 to 66.
08 October 2019, 07:20:17
Немного подкорректировал азимут (поставил по центру)
08 October 2019, 07:32:33
24 October 2019, 13:44:21
Сегодня стоит.
25 October 2019, 16:45:36
у меня кстати андроид не сработал, хотел добавлять уже
24 October 2019, 13:44:36
24 October 2019, 13:45:49
Не мото -1
30 October 2019, 17:20:32
Shorochov, changed warning start time from 0 to 6.
Shorochov, changed warning end time from 24 to 18.
13 November 2019, 15:19:15
Shorochov, changed warning end time from 18 to 20.
17 December 2019, 09:38:01
05 February 2020, 13:03:22
Подтверждено 2020-02-02 08:32:25 (UTC±00:00)
     Вероятность: 66 %  (Частота за прошлый месяц)
06 March 2020, 19:27:25
Подтверждено 2020-03-02 14:26:42 (UTC±00:00)
     Вероятность: 67 %  (Частота за прошлый месяц)
25 March 2020, 09:38:31
balabol.1974, changed object description from 'Стрелка-М' to 'Стрелка-М [25км 940м]'.
25 March 2020, 09:40:13
25 March 2020, 09:40:38
актуально +1
25 March 2020, 09:40:41
актуально +1
06 September 2020, 07:49:23
17 January 2022, 13:04:17
Нет в базе! -1
17 January 2022, 13:04:20
Нет в базе! -1
17 January 2022, 13:04:22
Нет в базе! -1
17 January 2022, 13:18:06
См выше -1
17 January 2022, 13:18:09
См выше -1
17 January 2022, 14:26:42
См выше -1
17 January 2022, 14:26:44
См выше -1
