20 November 2026, 08:42:24
Контроль скорости, экипаж ДПС
04 June 2015, 13:38:28
04 June 2015, 14:02:38
action_64, changed warning direction from 291 to 289.
action_64, changed object view angle from 15 to 25.
08 June 2015, 05:51:11
4
16 July 2015, 09:52:34
статистика, засада наблюдается http://mapcam.info/speedcam/point.php?idx=794291
16 July 2015, 09:53:33
, changed object view angle from 25 to 35.
16 July 2015, 09:53:52
есть актуальное подтверждение, рейтинг точки от 2 +1
20 August 2015, 21:09:44
зачастили они здесь стоять +1
20 September 2015, 12:37:54
s.kord, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!).
14 October 2015, 21:23:51
стоят с завидной постоянностью
04 November 2015, 14:31:31
Наблюдается: http://mapcam.info/speedcam/point.php?idx=911211.
10 November 2015, 14:31:58
Наблюдается: http://mapcam.info/speedcam/point.php?idx=913088.
11 November 2015, 21:56:22
Наблюдается: http://mapcam.info/speedcam/point.php?idx=913510.
21 November 2015, 11:16:15
Наблюдается: http://mapcam.info/speedcam/point.php?idx=915997.
19 January 2016, 15:14:03
valur111, changed warning direction from 289 to 287.
valur111, changed object view angle from 35 to 45.
19 January 2016, 15:15:04
      Декабрь 2015г., вид при движении из Питера в Москву.
19 January 2016, 15:15:26
Никого не было.
19 January 2016, 15:16:23
valur111, changed object description from 'Мобильная камера (засада)' to 'Контроль скорости, экипаж ДПС'.
16 February 2016, 14:09:12
14.02.2016 Стоял экипаж. Ночью. Обслуживал клиентов.
16 February 2016, 14:49:00
Да. И 22.01.2016 тоже ночью и тоже стояли.
16 February 2016, 14:10:47
gorik77, changed object latitude from 36.099486 to 36.099481
gorik77, changed object longitude from 56.782439 to 56.782457
16 February 2016, 14:12:27
gorik77, changed warning direction from 287 to 290.
gorik77, changed object notification distance from 500 to 700.
gorik77, changed object view angle from 45 to 35.
17 February 2016, 14:44:14
valur111, changed warning direction from 290 to 287.
17 February 2016, 14:49:14
valur111, changed warning direction from 287 to 285.
valur111, changed object notification distance from 700 to 690.
29 March 2016, 22:13:32
      Начало марта 2016г., вид при движении из Питера в Москву
29 March 2016, 22:14:02
Не было.
30 March 2016, 07:18:31
Дислокация постоянно меняется в течении дня. От Светофора на Тургиново до п. Смолино. На объездной Твери сейчас реконструкция и установлены временные знаки ограничения скорости вплоть до 40км/ч. Очень часто на том участке стоят
30 March 2016, 12:45:45
Вы абсолютно правы. Основными местами являются это, а так же в середине Эммауса и на повороте Новое Семеновское (район Смолино). Значительно реже в районе поворота на Губино.
16 May 2016, 13:52:17
15.05.2016 стоял экипаж
03 July 2016, 22:31:47
актуально
постоянно появляются
10 September 2016, 15:14:32
для статистики: весь август не было
19 September 2016, 15:32:17
18.09.2016 стоял экипаж ночью и бдительно мониторил поток
19 September 2016, 21:05:53
без радара?
20 September 2016, 12:42:51
Все, что надо - у них в машинке...
В руках только палки-махалки.
20 September 2016, 07:31:54
18.09.2016 - стояли с утра
21 September 2016, 01:23:14
видел, РД на них не срабатывал, видимо документы и 20.25
12 January 2017, 08:34:16
в работе по скорости так замечены и не были + по информации от Тверских гайцов скоростной режим только в автоматическом режиме фиксируется (патрули этим не занимаются)
12 January 2017, 08:35:27
не опасно
см выше
карму вернул
нужны еще минуса -1
12 January 2017, 12:26:07
Удаляем?
12 January 2017, 17:03:42
предлагаю пока в "ноль"...
уж больно раньше излюбленное место было
12 January 2017, 08:57:36
См.выше. Автору карму вернул. -1
12 January 2017, 08:59:39
Ниже 1 опускать, не стоит.
Периодически стоят и в любой момент могут начать Контроль скорости.
12 January 2017, 09:07:21
В комментах к одному из объектов расширенно писал о беседе по душам с тверскими гаишниками.. Фиксация скоростного режима патрулями не ведется, эти функции полностью на отдельном подразделении - гражданские ларгусы с треногами, ну и привычные нам стационарные объекты. Мое мнение - трасса "Россия" в базе должна находиться в актуальном состоянии и не актуальным объектам не место. Если что-то изменится, то всегда можно это оперативно исправить.
12 January 2017, 09:13:22
Правильно ли я вас понимаю, что все мобильные засада (контроль скорости) в Тверской области представлены к удалению?
12 January 2017, 10:46:47
ниже
12 January 2017, 10:46:23
Нет. Не правильно.
Вот пример idx=927140
Теперь мобильные засады на скорость выглядят в виде сныканного в кусты белого ларгуса и выставленной треноги. Таким образом патрули за скорость не останавливают. В принципе, и без разговора с гайцами это было заметно за крайние полгода.
Исходя из этого, база в регионе нуждается в актуализации касательно этого типа объектов. Особое внимание вновь появившемся  с подписью "стоял патруль".. А что он стоял, что делал? - ну Вы поняли)))
13 January 2017, 04:14:34
Рейтинг ноль. По просьбе -1
13 January 2017, 04:18:17
Карму компенсировал
30 January 2017, 02:46:13
Стоят периодически. Прошел мимо с превышением, на меня ноль внимания. Видел как останавливали ехавшего с эстакады со стороны Твери, но явно не за скорость.
29 May 2017, 16:30:04
(R)ound, changed additional information (RU): \"
10 July 2017, 17:26:12
08.07.2017 Ночью.
Стоял экипаж ДПС. Обслуживали клиента.
11 September 2017, 16:16:38
11.09.2017 Ночью.
Стоял экипаж ДПС. Просто стоял.
06 October 2017, 20:47:40
      Июнь 2017г. Не было.
18 December 2017, 19:02:27
13.12.2017 Ночью.
Стоял экипаж ДПС. Обслуживали внедорожник.
18 March 2018, 13:37:51
02.09.2017г. днём не было.
04 July 2019, 06:12:28
Не актуально -1
18 November 2019, 20:09:32
Сегодня примерно в 17:30 стояли, обслуживали большегруз. Еще месяц-два назад стояли. Бывают здесь крайне редко
25 November 2019, 15:47:35
Сегодня 25.11 в 18:06 стояли, что контролируют - неясно.
24 December 2019, 17:23:43
24 December 2019, 17:24:36
24.12, примерно 19:40, стоял ДПС автомобиль, самих сотрудников не было видно, наверно, были в авто
15 January 2020, 15:11:20
Вчера 14.01 примерно в 16:40 стояли, ехал через мост, остановили автомобиль неизвестно за что, который ехал прямо передо мной, хотя было основание остановить меня.
15 January 2020, 15:59:29
и вот поэтому такие "засады" должны быть в базе!
16 January 2020, 06:40:52
Если будет соответствующий тип точки "Просто засада ДПС".
16 January 2020, 16:59:28
Тип уже есть. Называется "Мобильная камера (засада)". Но не используется.
16 January 2020, 17:01:38
Не согласен. Где в данной засаде камера?
16 January 2020, 17:24:59
Камера не обязательна. Достаточно экипажа ДПС.
