22 October 2026, 05:46:15
Билюково
Russian Federation > Ивановская область
26 August 2018, 09:10:44
26 August 2018, 16:25:39
tigon, changed speed limit from 80 to 60.
tigon, changed warning direction type from Two directions to In a certain direction.
tigon, changed warning direction from 286 to 289.
tigon, changed object view angle from 15 to 45.
tigon, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Билюково'.
tigon, confirmed object added via Mapcam.info program
tigon, changed additional information (RU): \"
26 January 2025, 17:46:21
Прошу удалить, убрали. Похоже н.п. обнулили.
29 January 2025, 06:26:02
Отсутствует -1
29 January 2025, 06:26:04
Отсутствует -1
29 January 2025, 06:26:06
Отсутствует -1
29 January 2025, 07:52:52
См выше Удалил -1
29 January 2025, 07:52:55
См выше Удалил -1
29 January 2025, 07:52:57
См выше Удалил -1
29 January 2025, 07:53:07
