22 October 2026, 03:52:10
КОРДОН-М 2 [14км 930м]
29 April 2016, 17:46:31
29 April 2016, 17:47:20
malahit79, changed control area.
29 April 2016, 17:53:22
silandser, changed warning direction from 349 to 341.
silandser, changed object view angle from 25 to 45.
30 April 2016, 09:03:35
Крайне необходимо фото объекта. Спасибо.
30 April 2016, 11:20:57
будет как нибудь
05 May 2016, 05:53:18
смените ограничение скорости на 60, ограничения 40 нет
05 May 2016, 06:37:56
malahit79, changed speed limit from 40 to 60.
05 May 2016, 06:38:52
malahit79, changed object description from 'Автодория. ограничение 40' to 'Автодория. ограничение 60'.
06 August 2017, 13:43:43
06 August 2017, 13:54:28
2maxic, changed object latitude from 60.016653 to 60.016842
2maxic, changed object longitude from 57.885304 to 57.884370
2maxic, changed control area.
06 August 2017, 14:08:36
06 August 2017, 14:10:23
Передвинул по координатам выше.
17 September 2017, 06:53:29
27 September 2017, 17:19:22
27 September 2017, 19:59:24
штрафует, актуально +1
18 November 2017, 16:29:28
12 December 2017, 14:53:17
26 July 2018, 10:08:11
Существует, работает. +1
22 August 2018, 19:33:29
22 August 2019, 15:20:19
yuryleb, changed warning direction from 341 to 350.
yuryleb, changed object notification distance from 300 to 250.
yuryleb, changed object description from 'Автодория. ограничение 60' to 'Автодория'.
22 November 2020, 14:35:16
26 April 2023, 09:11:15
26 April 2023, 09:11:41
заработал по мгновенной скорости
26 April 2023, 11:30:22
работает на 40 ! ! !
27 April 2023, 03:46:07
2maxic, changed object latitude from 60.016842 to 60.016980
2maxic, changed object longitude from 57.884370 to 57.884030
2maxic, changed object type from  Twin camera Twin camera to  Static speed camera Static speed camera.
2maxic, changed speed limit from 60 to 40.
2maxic, changed warning direction from 350 to 175.
2maxic, changed object notification distance from 250 to 500.
2maxic, changed object view angle from 45 to 20.
2maxic, changed object description from 'Автодория' to 'Автодория 3.5 [14км 930м]'.
2maxic, changed camera model.
2maxic, changed additional information (RU): \"
27 April 2023, 03:46:37
До нуля -1
27 April 2023, 03:46:49
До 2 -1
27 April 2023, 03:46:53
До 2 -1
04 May 2023, 11:50:09
05 May 2023, 05:15:35
По просьбе -1
18 August 2023, 04:12:00
камеру перенесли ближе к перекретску(см координаты), и она не парная !
19 August 2023, 16:19:03
Автодория 3.5 не парная. Укажите координаты, перенесем.
19 August 2023, 16:20:52
2maxic, changed object latitude from 60.016980 to 60.016910
14 February 2024, 10:10:26
17 February 2025, 06:29:14
, changed object description from 'Автодория 3.5 [14км 930м]' to 'Кордон М2 [14км 930м]'.
17 February 2025, 09:17:36
, changed object description from 'Кордон М2 [14км 930м]' to 'КОРДОН-М 2 [14км 930м]'.
