04 November 2026, 08:40:34
For the past 24 hours: 61 object added, 71 object edited, 6 objects removed.
АТОМ-ИС [275км 580м]
Russian Federation > Псковская область
06 May 2021, 21:40:00
06 May 2021, 21:44:18
06 May 2021, 21:45:26
07 May 2021, 07:59:31
Timon34, changed object type from  Integrated camera Integrated camera to  Static speed camera Static speed camera.
Timon34, changed object notification distance from 561 to 550.
07 May 2021, 08:00:03
Timon34, changed object description from 'Встроенная камера' to 'Декарт'.
07 May 2021, 08:00:34
07 May 2021, 08:01:01
Просьба к автору добавить отдельную парную точку в спину. Если будут вопросы - пишите
21 May 2023, 21:47:42
kenalog, changed object description from 'Декарт' to 'АТОМ-ИС [275км 580м]'.
21 May 2023, 21:48:46
направление камеры уточните
22 May 2023, 11:30:24
Теперь она справа на столбе и тоже другой тип камеры атом, я в командировке не могу пока фото добавить.
28 May 2026, 04:51:43
, changed object latitude from 28.536998 to 28.536918
, changed object longitude from 57.865318 to 57.865352
28 May 2026, 04:52:21
Подправил...
28 May 2026, 05:32:08
, changed object latitude from 28.536918 to 28.537376
, changed object longitude from 57.865352 to 57.865521
04 August 2026, 08:24:38
камера на 90 -1
04 August 2026, 10:05:47
Просьба не трогать рейтинг, достаточно комментария.
См.п.1.9
https://mapcam.info/help/set_objects.php
04 August 2026, 10:06:09
Воврат +1
04 August 2026, 11:18:25
