22 October 2026, 05:46:06
КОРДОН-М 2
15 February 2017, 17:00:43
15 February 2017, 18:56:12
Неверный тип точки при контроле скорости.
15 February 2017, 19:00:16
По документам камера в основном сечет выделенную полосу ОТ, но и скорость Автопотруль то же может мерить.
15 February 2017, 19:02:00
morfiuz, changed object description from 'Автоапатруль, 1 полоса, замер скорости.' to 'Автоапатруль 1 полоса ОТ + замер скорости.'.
16 February 2017, 01:52:02
16 February 2017, 06:13:05
silandser, changed object type from  Lane Control Camera Lane Control Camera to  Traffic control complex Traffic control complex.
16 February 2017, 06:13:29
Если два вида нарушений, то это КК ПДД. Исправил
17 February 2017, 10:53:19
morfiuz, changed object description from 'Автоапатруль 1 полоса ОТ + замер скорости.' to 'Кардон М4 1 полоса ОТ + замер скорости.'.
17 February 2017, 10:58:50
morfiuz, changed object description from 'Кардон М4 1 полоса ОТ + замер скорости.' to 'Кордон М4 1 полоса ОТ + замер скорости.'.
30 December 2017, 19:51:39
30 December 2017, 19:51:59
30 December 2017, 19:52:51
Штрафует. +1
09 January 2018, 21:43:23
09 January 2018, 21:43:53
прохоров, changed object description from 'Кордон М4 1 полоса ОТ + замер скорости.' to 'Кордон М2 1 полоса ОТ + замер скорости.'.
09 January 2018, 21:44:25
движение по полосе ОТ
09 January 2018, 21:48:07
Вот ещё информация по выезду на полосу ОТ на Широтной,183
19 January 2018, 12:47:19
превышение скорости
превышение скорости
07 May 2018, 19:14:19
16 July 2018, 11:58:11
прохоров, changed object description from 'Кордон М2 1 полоса ОТ + замер скорости.' to 'КОРДОН-М 2'.
16 July 2018, 12:01:56
28 December 2018, 03:42:09
01 August 2018, 18:46:28
01 August 2018, 18:46:38
17 January 2019, 09:07:15
Primorets, changed object latitude from 65.617490 to 65.617437
Primorets, changed object longitude from 57.097500 to 57.097478
17 January 2019, 09:07:46
Передвинул на середину дорожного графа
17 January 2019, 09:07:59
17 January 2019, 09:08:20
17 January 2019, 09:39:52
Для мото неактуально. -1
17 January 2019, 09:53:50
18 July 2019, 11:57:57
19 November 2020, 03:55:05
03 September 2022, 07:21:29
Демонтировали -1
03 September 2022, 07:21:36
Демонтировали -1
03 September 2022, 07:21:44
Демонтировали -1
03 September 2022, 07:24:28
На удаление -1
03 September 2022, 07:24:32
На удаление -1
03 September 2022, 08:20:15
См. выше -1
03 September 2022, 08:20:23
См. выше -1
03 September 2022, 08:27:22
Elen, changed warning direction from 125 to 117.
Elen, changed object notification distance from 500 to 100.
03 September 2022, 09:38:17
Удаление -1
03 September 2022, 09:38:21
Удаление -1
