22 October 2026, 21:38:19
Азимут 4 (тыл) [52км 706м]
19 October 2017, 15:08:38
28 January 2018, 11:06:41
Hyundi505, changed object latitude from 37.094902 to 37.094704
Hyundi505, changed object longitude from 56.106226 to 56.106402
28 January 2018, 11:06:52
Замер
28 January 2018, 19:05:06
А по координатам из штрафа точка получается после пешеходки. Хотя на фото не попадает она.
28 January 2018, 19:03:21
28 January 2018, 19:03:30
28 January 2018, 19:03:49
Поднимаю, подтверждено штрафом! +1
11 March 2018, 15:20:05
valur111, changed object latitude from 37.094704 to 37.094750
valur111, changed object notification distance from 400 to 550.
11 March 2018, 15:21:25
На дорогу по трекам.
      Добавил дистанцию, т.к. на входе в НП.
07 April 2018, 13:45:59
28 May 2018, 14:39:03
28 May 2018, 14:40:54
05 June 2018, 05:28:02
21 July 2018, 05:31:16
21 July 2018, 05:31:36
23 August 2018, 13:07:57
23 August 2018, 13:08:05
Фоторепортаж
24 September 2018, 17:57:00
27 September 2018, 06:28:36
Для мото в 0 -1
10 November 2018, 19:37:30
15 January 2019, 23:30:39
, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 (52км 706м)'.
25 February 2019, 21:35:17
25 February 2019, 21:35:32
25 February 2019, 21:36:47
Подтверждено штрафами +1
25 February 2019, 21:36:51
01 August 2019, 15:46:21
12 May 2020, 13:15:03
fantompg, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
12 May 2020, 13:16:53
12 May 2020, 13:17:00
28 January 2021, 04:35:44
Информация с сайта ГИБДД: https://гибдд.рф/milestones/2855071/
Московская область, АвтоУраган №AS5000855. Адрес: а/д М-10 «Россия», 52км 706м, н.п. Есипово
28 January 2021, 04:38:47
Информация с фото штрафа:
Датчик: AS5000855
Направление: в Москву
GPS: 56.106182, 37.094688
28 January 2021, 04:39:19
(R)ound, changed object description from 'АвтоУраган-ВСМ-2 (52км 706м)' to 'АвтоУраган-ВСМ-2 [52км 706м] AS5000855'.
13 June 2021, 09:59:45
balabol.1974, changed object description from 'АвтоУраган-ВСМ-2 [52км 706м] AS5000855' to 'АвтоУраган-ВСМ-2 [52км 706м]'.
27 June 2021, 14:56:30
27 June 2021, 14:57:00
27 June 2021, 14:57:25
27 June 2021, 14:57:52
27 June 2021, 16:00:27
В данном скан актуальное направление не в Москву а из Москвы. Просьба добавить скан в актуальное направление.
28 June 2021, 04:55:51
Я ехал из Москвы, камера направлена на Москву... другого нет...
28 June 2021, 10:41:32
Камеру развернули, и сейчас она смотрит в сторону Москвы. А на фото видна двойная сплошная, то есть фото со встречной полосы.
28 June 2021, 10:45:32
Ваш скан уже добавлен в актуальное направление из Москвы!
27 June 2021, 14:58:56
Развернули... теперь стреляет и москва, и область. На фото я, ехал в область в это время...
27 June 2021, 15:48:16
balabol.1974, changed object latitude from 37.094750 to 37.095086
balabol.1974, changed object longitude from 56.106402 to 56.106275
balabol.1974, changed warning direction from 330 to 149.
balabol.1974, changed object notification distance from 550 to 400.
balabol.1974, changed object view angle from 25 to 20.
27 June 2021, 15:49:59
В скан указано ошибочное направление
27 June 2021, 15:54:02
balabol.1974, changed object latitude from 37.095086 to 37.094952
balabol.1974, changed object longitude from 56.106276 to 56.106236
balabol.1974, changed object type from  Traffic control complex Traffic control complex to   .
balabol.1974, changed warning direction from 149 to 329.
balabol.1974, changed object notification distance from 400 to 300.
balabol.1974, changed object description from 'АвтоУраган-ВСМ-2 [52км 706м]' to 'АвтоУраган-ВСМ-2 (тыл) [52км 706м]'.
27 June 2021, 15:56:32
актуально +1
28 June 2021, 10:48:24
до подтверждения работы в спину -1
28 June 2021, 10:48:28
03 July 2021, 09:50:02
Насколько мне понятно камера поменяла направление, и теперь захватывает и встречную полосу.  Про направление врет, я ехал с Москвы. [img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAA5EAAAN6CAYAAAAXUc3 AAAgAElEQVR4AezdBdP1ynGu4fybMDOjHWamHXYcZmZmZubEDjMzMzM7zMykU5cq964uRVprfZizz9FbNR5poKenp2f6eUbr236q5fw7LXBa4LTAaYHTAqcFTgucFjgtcFrgtMBpgdMCN1rgqW5sdzY7LXBa4LTAaYHTAqcFTgucFjgtcFrgtMBpgdMCy0kiTyc4LXBa4LTAaYHTAqcFTgucFjgtcFrgtMBpgZstcJLIm011NjwtcFrgtMBpgdMCpwVOC5wWOC1wWuC0wGmBk0SePnBa4LTAaYHTAqcFTgucFjgtcFrgtMBpgdMCN1vgJJE3m pseFrgtMBpgdMCpwVOC5wWOC1wWuC0wGmB0wIniTx94LTAaYHTAqcFTgucFjgtcFrgtMBpgdMCpwVutsBJIm821dnwtMBpgdMCpwVOC5wWOC1wWuC0wGmB0wKnBa6SyH/7t3971Er//M//vD5X9u///u/Lf/zHf6xl5V6qf7Tjfz/853/ 5yL191//9V89rnLIm/Uq57vnOc4c3/O//uu/PipPW/IlfeikzRxzytZRuyk/Yck5eld SW79amfc0lb2bFv72swxZrujcm3mWph/MpXXT65u2kNZ9kzXOWZytmXzPXs3Tn2Ub 2szRxf297Lp zqyUrebEde4yo3Xu9bOcr31l452du/KWc a e9ZNyp06zfytTOWFPekd7JLU/Wdg7poVxbf/L2Qv32cn3zHc/ZeK9tstVNe83y imT5jyr28u3MrbrOOVs5TZWdimfMmszxyYzucmsXX3Vz7nWX3l9lGV7ufb1V fZHmssZ
03 July 2021, 10:47:11
Не надо менять настройку предупреждения. Фото добавится когда его размер будет менее 1Мб формат jpg
03 July 2021, 20:46:24
Фото
04 July 2021, 06:53:47
В скан бывают ошибки. Ваш скан из Москвы!
03 July 2021, 09:53:25
versionbox, changed control area.
versionbox, changed warning direction from 329 to 144.
versionbox, changed object notification distance from 300 to 147.
versionbox, changed object view angle from 20 to 24.
03 July 2021, 10:45:16
balabol.1974, changed warning direction from 144 to 329.
balabol.1974, changed object notification distance from 147 to 300.
balabol.1974, changed object view angle from 24 to 20.
09 February 2022, 20:32:57
09 February 2022, 21:09:54
актуально +1
25 December 2022, 19:26:49
kroxan, changed object description from 'АвтоУраган-ВСМ-2 (тыл) [52км 706м]' to 'Азимут 4 (тыл) + АвтоУраган-ВСМ-2 (тыл) [52км 706м]'.
kroxan, changed camera model.
25 December 2022, 19:28:06
kroxan, changed additional information (RU): \"
08 April 2023, 10:19:34
007MCD, changed object description from 'Азимут 4 (тыл) + АвтоУраган-ВСМ-2 (тыл) [52км 706м]' to 'Азимут 4 (тыл) [52км 706м]'.
03 December 2023, 19:48:42
03.12.2023. Работает получил штраф, превышение скорости.
03 December 2023, 19:54:04
Просьба выложить фото/скрин штрафа , личные данные можете затереть.
28 December 2023, 19:17:16
