22 October 2026, 05:46:16
Встроенная камера(Крис)
08 March 2022, 13:26:11
09 March 2022, 20:05:39
atspitus, changed object latitude from 30.795283 to 30.795354
atspitus, changed object longitude from 61.777403 to 61.777403
atspitus, changed control area.
atspitus, changed object type from   to  Integrated camera Integrated camera.
atspitus, changed speed limit from 0 to 60.
atspitus, changed warning direction type from Two directions to In a certain direction.
atspitus, changed warning direction from 151 to 156.
atspitus, changed control direction from Counter direction to In the back.
atspitus, changed object notification distance from 500 to 250.
atspitus, changed object view angle from 15 to 65.
atspitus, changed object description from 'Объект добавлен 2022-03-08 12:58:23 с помощью MapcamDroid' to 'Встроенная камера(Крис)'.
atspitus, confirmed object added via Mapcam.info program
atspitus, changed warning start time from 0 to 8.
atspitus, changed warning end time from 24 to 22.
atspitus, changed camera model.
09 March 2022, 20:06:54
atspitus, changed control direction from In the back to Both directions.
09 March 2022, 20:10:25
atspitus, changed control direction from Both directions to In the back.
14 August 2022, 17:14:35
-2
13.08.2022 Ящик пустой -1
05 September 2022, 23:29:10
По просьбе +1
06 September 2022, 16:06:02
Timon34, changed warning direction from 156 to 174.
06 September 2022, 16:07:46
Поправил, чтобы сработка начинала происходит сразу после въезда в луч, а не через несколько сотен метров. Как правильно настраивать точки на сложных графах подробно расписано в расширенной справке (есть на форуме)
