22 October 2026, 04:51:55
Кречет
04 December 2019, 06:41:03
04 December 2019, 07:40:20
Yoburger, changed camera model.
02 May 2020, 15:04:38
09 July 2020, 22:47:26
setpiton, changed object latitude from 55.968502 to 55.968461
setpiton, changed object longitude from 54.718655 to 54.718726
setpiton, changed warning direction from 249 to 245.
setpiton, changed object notification distance from 500 to 400.
setpiton, changed object view angle from 15 to 30.
02 November 2022, 14:40:59
02 November 2022, 14:41:26
02 November 2022, 14:41:30
02 October 2023, 12:03:10
02 October 2023, 12:03:29
демонтаж нужен минус -1
02 October 2023, 12:03:32
02 October 2023, 12:03:34
03 October 2023, 14:47:39
fed, changed object latitude from 55.968461 to 55.964373
fed, changed object longitude from 54.718726 to 54.717681
fed, changed warning direction from 245 to 227.
03 October 2023, 14:48:47
Камеру переместили. Откорректировал.
10 July 2024, 09:26:03
камеры нет, на месте висит видимо муляж, но точно не кречет.
https://yandex.ru/maps/172/ufa/?ll=55.966197,54.718040
10 July 2024, 09:28:48
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAXgAAAHHCAIAAAA6Y9RRAAAgAElEQVR4AXy9V5BkWXoeVjuuu7pcVmVWZtn0rrw3bWZneqbN J51RAgRoqQHhRgiCRBEhCBwF9OVeb03WT3r/YIMygX5AEghLSARoESQIAkTepACZjHdlfced2/27ALcCOlF8Z TldNcSIo4kZGVnZ1Zbe5X3/ ZP8eaAWsGrBUmrYC1AtYIaM3DNQ/XfVIPaD2EUwtI1cfi1H3SCCj8Fp u 6zlkbqDanZcd3HDp/DbAzJ8fkAaPl1z4bRc0nBxnT h4qF6QJohvF3Tpw0XV8OkGNByLykHtOjiik8rPi17pOKRqk8rHik5qBawqs qHq248Dj8kkeHX7qk4pKyg8s2qlhRzY7qdty04pYVt 140yHbLtl2yI6Fti20Z9Ntg 4YbNti6xZtWaTuwmuWHFx08aoHpxTQEv97qLqo4uFawCo LTp41cZll5UdWrZJyaIVC1dtVHNQzYprZtywUMshbZc2HdKwcd0lNY80HNy2UduO207cdlDLiZt2NDotO KPx00nrtn9utOvu7ju4qodl42oZMRFA4lTNnDdwE0DNUzcsHDNwnWH1BxSsVDViBsWbtu0bZK6iSoWKptxyYgqRlw1Uc3CDZu0HNpyaNOGJ9QtVHdQw4obZtQy400Tb1lk26bbNt106LpD1hyyZeN9mxw4dN8m/A45dMiBjQ/s NCKTxx86pJDn 4GdM nhz479pPrHr3hs5tBcjOkpwE5CchJSPZDvBnE 37/tvfk/RAd/tK/yH3mH1159x9 6p3vj7317bE3v/rcvfD516znXjWu3HVfvON 6rbzqdv 2CvBc298/Y790W0f3fLRjYAc  TYZ0ceO/YoHJceO/TQIYdwy4 NDy18ZJIjixzZ9MAi xbZs iuRXcs KNt28mWA2fHZNsG3tQp3DHZpknXzWTNYG2Drlvpuj1o6rSiorIaV3RU0VFZi8saqhmkZpCyhkpqVNEQP3hZwYsSWpLxikpXNLak0iUZLylkRSGrCi3JtCSRgkTnuzjXxXmZzCtkTsZzEsp0otmzqCCRJZktdHFeovMSy3ZITmIFJcmpyaxMZhQ6o9BJGU rdJrfz0hktoNz/MmFLlkSR8JLMl6U8YKM8zLKqTSrkJyM5yW8KNMVhcC3IdOySooKXpHRkhwvyWhBQtmz/rwU57rRXKefleOcFM3LcUHBBRkXunG E U6Ua4bZTt9ceBp3X5OGj4yL8XzUpzvxEtdVNKSAn9 XkaznYt5BeVVnFdxQYFvKd FdxmrB6Tm4UZAW2HS8Agcn9R9DgS9pNVLmr2kEdKaP4QPATQATBxo1jxAioaLATUCVvOGeFTxcTUgzQDAaN1nTY9UXQT4FZCyG9d8eEeBMnBdhUk5ZLVHg1qYFB20YsfVgFUDVgtYPUzgOvcI3AmTig/3Sy4uu1jAUNkl/GAAIBdX7LhqxwB8dty0UctCaw7ZcOAS2rTIlk12HbZjsU2Dbphk3WZrXtIA7MCrdrxixytOvGxHS1Z/0bwoWf2yG5fcuOigVQ vuHjFJWU/KXtJyWEANCaumXHLwU0Hw3VrwTu2XSIeafLH2zZes3DbQm0btzna1hxUd3HT48hrRk0zXnNI04YrH75tE9VMwI66SWoWhWMnNTup20nDpAJlGhw7mg5tOhTum6hl4XUbc6ABtF01o6LeL r9qokEyqw5DI5NWyZpmKhq9qv6RU3vtyy05dBtl22JvyKbrDtwNh2865A9l 45ZM8h y7Zd8iejfdstG jQxcf 8mBT3Z8tOeRAw8feeTUJdd9eisEoLkRkNOAnIb06JztP2LHIXrF eh9/2L/F343  DXx9/9/vPvfnfsnW9 6q2vPXc/fP6O/fzr2tU3nPF77ouv2S 86o192hs7MV/V//R1P341xJ8O2Y2AHAR4L0QHXnxixzcddsNmRw498Niexw7c5MShNyx6Z
10 July 2024, 09:31:22
10 July 2024, 11:33:09
Лучше фото с телефона или скрин с регистратора (если на нём что-то можно увидеть). Панорамы 23года не нужно.
10 July 2024, 11:30:14
10 July 2024, 11:30:18
10 July 2024, 11:33:48
10 July 2024, 15:29:01
10 July 2024, 15:29:11
