21 November 2026, 02:00:03
Belarus > Минская область
24 February 2011, 20:43:40
SERGEY12RUS, changed object latitude from 27.626266 to 27.626266
SERGEY12RUS, changed object notification distance from 500 to 211.
SERGEY12RUS, changed object description from '' to 'Лежачий полицейский'.
23 July 2012, 14:36:16
точно!
+1
23 July 2019, 18:55:40
Alissandru, changed object notification distance from 211 to 150.
06 August 2019, 09:25:56
Прошла реконструкция дороги, объекта нет и не будет. Удалите его, пожалуйста
19 September 2019, 19:35:47
Andrey80.by, changed object notification distance from 150 to 100.
21 September 2019, 07:47:54
После реконструкции его нет -1
21 September 2019, 07:47:57
21 September 2019, 07:47:59
21 September 2019, 08:14:02
На удаление -1
21 September 2019, 08:14:05
На удаление -1
21 September 2019, 08:14:15
На удаление -1
21 September 2019, 09:05:28
21 September 2019, 09:05:33
21 September 2019, 09:05:38
21 September 2019, 09:06:06
feudor10, changed warning direction type from Two directions to In a certain direction.
feudor10, changed object view angle from 15 to 10.
23 September 2019, 18:51:15
на удаление -1
23 September 2019, 18:51:19
на удаление -1
23 September 2019, 18:51:22
на удаление -1
14 December 2019, 16:14:31
Andrey80.by, changed object latitude from 27.626266 to 27.626263
Andrey80.by, changed object longitude from 53.920383 to 53.920423
Andrey80.by, changed warning direction type from In a certain direction to Two directions.
Andrey80.by, changed object view angle from 10 to 25.
14 December 2019, 16:15:00
Вернули после реконструкции +1
14 December 2019, 16:15:03
14 December 2019, 16:15:05
15 December 2019, 06:39:08
Andrey80.by, changed object view angle from 25 to 15.
15 December 2019, 06:40:06
Andrey80.by, changed object view angle from 15 to 20.
15 December 2019, 06:52:19
См. выше +1
15 December 2019, 06:52:27
См. выше +1
15 December 2019, 06:52:32
См. выше +1
15 December 2019, 06:55:36
По просьбе +1
15 December 2019, 06:55:45
По просьбе +1
15 December 2019, 06:55:49
По просьбе +1
