15 September 2026, 05:20:21
For the past 24 hours: 121 object added, 170 objects edited, 25 objects removed.
Стрелка-Плюс [20км]
17 February 2021, 13:46:24
17 February 2021, 14:06:20
balabol.1974, changed object type from   to   .
18 February 2021, 17:51:25
Она тут в лицо направлена
18 February 2021, 17:55:43
Просьба добавьте фото
18 February 2021, 17:56:16
balabol.1974, changed object type from   to  Static speed camera Static speed camera.
18 February 2021, 17:56:33
balabol.1974, changed object description from 'Стрелка-Плюс (тыл)' to 'Стрелка-Плюс'.
20 February 2021, 18:02:08
12 April 2021, 05:50:04
12 April 2021, 05:50:25
12 April 2021, 05:50:30
19 April 2021, 10:10:36
22 April 2021, 20:10:19
Хороший способ сруба денег. Ставить камеру на 60 сразу после съезда с МКАД. Хотя бы на 80 уж поставили. Чистая камера для прибыли, под соусом безопасности.
22 April 2021, 20:16:25
balabol.1974, changed object view angle from 10 to 15.
22 April 2021, 20:21:31
27 April 2021, 11:22:46
Если ехать по МКАДу, в 2ух правых рядах, то приложение её цепляет.
07 May 2021, 04:33:40
intruder197, changed object latitude from 37.778110 to 37.778107
intruder197, changed object longitude from 55.615088 to 55.615128
intruder197, changed warning direction from 224 to 220.
07 May 2021, 04:38:42
Немного поправил оповещение, попробуйте, кто там часто бывает
25 May 2021, 19:17:02
26 August 2021, 18:09:11
Доп  датчик установлен
27 August 2021, 08:10:11
15 October 2021, 13:09:51
24 March 2022, 16:48:08
Штраф. подленькое место. со 110 сбросить до 78, прямо надо знать +1
24 March 2022, 16:53:34
достаточно рейтинг 2 -1
24 March 2022, 17:46:28
balabol.1974, changed warning direction from 220 to 221.
balabol.1974, changed object notification distance from 340 to 400.
11 April 2022, 08:09:39
11 April 2022, 11:30:05
balabol.1974, changed object description from 'Стрелка-Плюс' to 'Стрелка-Плюс [20км]'.
26 May 2022, 19:19:16
05 June 2022, 06:55:06
05 June 2022, 07:11:51
камера работает оперативно вчера нарушение сегодня уже штраф ((
16 July 2022, 08:43:58
это как вообще со 100км до 60 затормозить ногой в пол? Лучшеповесть знак "кормушка ССС"
16 July 2022, 09:51:03
balabol.1974, changed object notification distance from 400 to 500.
17 July 2022, 05:56:29
Это как вообще едешь по мкаду 100 кмч вдруг знак  и ты должен ногой в пол тормозть до 60? Потому что через 100 метров после знака сразу же камера. Кормушка и есть. Нужно жаловаться в ГИБДД на такую хрень ибо если там все будут ногой в пол тормозить то начнутся массовые ДТП.
17 July 2022, 07:11:06
В TTS первым прописано На дублёре. Или вы хотите чтобы люди На дублёре должны не получать предупреждение о камере на 60. Попробуйте сделайте лучше. А ещё лучше правильно настройте программу.
17 July 2022, 11:49:05
Я о целессобразности такого резкого ограничения скорости. Про вашу "программу" вообще не слова. Представьте что едет пожилой человек без навигатора.
20 May 2023, 08:12:28
Ну фиг знает. Ездию там переодически. Ни разу не нарывался. Но вот схватил, на 83.км.ч....
15 August 2022, 11:03:26
сначала около разделяющего отбойника висит знак отмены скоростного режима 100 км/ч и съезда со скоростной дороги, после него уже скорость должна быть ниже, и до камеры остаётся 150 метров (судя по кол-ву опор мачт освещения), а участок торможения судя по знаку вообще 350 метров, так что вроде как всё нормально по скоростным режимам.
28 August 2022, 09:25:19
21 February 2023, 21:38:14
21 February 2023, 21:38:43
12.9 ч.6 - повторное совершение административного правонарушения, предусмотренного частью 3 настоящей статьи
31 October 2023, 01:52:11
31 October 2023, 01:58:02
Полностью согласен с высказываниями выше - что эта камера предназначена только для сбора денег, других причин её нахождения здесь не существует. Хотя... я так считаю абсолютно про все камеры, в любых местах, и это моё абсолютно непоколебимое убеждение. :-)
08 May 2024, 16:03:09
, changed object latitude from 37.778107 to 37.778276
, changed object longitude from 55.615128 to 55.615353
, changed warning direction from 221 to 218.
11 June 2024, 17:35:27
01 August 2024, 17:55:06
14 October 2024, 09:45:23
Знак снижения скорости со 100 до 60 км/час висит за 150м от камеры. Это намеренно установленная ловушка по сбору денег (как и 99% всех камер в Москве) Будьте внимательны, не кормите своими деньгами мерзких упырей.
14 October 2024, 18:19:49
Это уже дублер, съезд, на них всегда 60
23 October 2024, 06:38:31
