16 November 2026, 00:58:33
КОРДОН-М 2 [1456км 80м]
fed
26 April 2019, 13:09:10
26 April 2019, 13:27:37
fed, changed speed limit from 70 to 90.
fed, changed speed limit from 0 to 70.
fed, changed warning direction type from Two directions to In a certain direction.
fed, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'КОРДОН-М 2'.
fed, confirmed object added via Mapcam.info program
26 April 2019, 13:28:37
fed, changed object latitude from 55.808674 to 55.808656
fed, changed object longitude from 54.676046 to 54.676113
fed, changed warning direction from 277 to 274.
26 April 2019, 13:29:17
26 April 2019, 13:29:35
26 April 2019, 16:47:30
Ноль. -1
26 April 2019, 16:47:43
РинатАли, changed camera model.
02 May 2020, 20:28:53
setpiton, changed object view angle from 15 to 25.
setpiton, changed object description from 'КОРДОН-М 2' to 'КОРДОН-М 2 [1456км 80м]'.
21 November 2021, 11:26:08
УльяновскGSM, changed object latitude from 55.808656 to 55.808273
УльяновскGSM, changed object longitude from 54.676113 to 54.676127
21 November 2021, 11:26:23
Подтверждено штрафом +1
21 November 2021, 11:26:25
21 November 2021, 11:27:18
21 November 2021, 18:23:06
22 November 2021, 19:56:15
fed, changed speed limit from 90 to 70.
10 January 2022, 06:51:04
14 February 2026, 08:17:59
Демонтаж.
14 February 2026, 08:18:42
14 February 2026, 08:18:50
24 February 2026, 18:04:13
см. выше -1
24 February 2026, 18:04:19
см. выше -1
24 February 2026, 18:04:24
см. выше -1
25 February 2026, 04:30:44
Выше Удалил -1
25 February 2026, 04:30:56
