22 October 2026, 13:24:42
Астра-Трафик [952км]
17 July 2017, 21:58:14
12 October 2017, 17:23:59
12 October 2017, 17:24:21
Актуально. +1
12 October 2017, 17:42:18
Timon34, changed object description from 'Автодория [Каспий 948-950км]' to 'Автодория [Р-22 Каспий 949-951км]'.
15 February 2018, 13:32:38
15 February 2018, 13:32:56
Актуально
14 May 2018, 20:16:19
29 May 2018, 06:35:36
04 October 2018, 18:28:39
Для мото неактуально -1
04 October 2018, 18:36:24
Двухколёсным не актуально -1
12 April 2019, 16:20:02
24 April 2019, 20:52:56
02 March 2020, 14:06:03
02 March 2020, 14:06:25
см выше, демонтаж -1
02 March 2020, 14:06:27
02 March 2020, 15:17:11
Смотреть выше -1
02 March 2020, 15:17:15
Смотреть выше -1
02 March 2020, 15:47:59
см выше 0 -1
02 March 2020, 15:48:02
см выше 0 -1
07 June 2020, 17:19:03
07 June 2020, 17:19:10
07 June 2020, 17:19:16
19 July 2020, 16:26:08
Timon34, changed object latitude from 44.357472 to 44.362643
Timon34, changed object longitude from 48.849842 to 48.848098
19 July 2020, 16:26:27
Timon34, changed object latitude from 44.362643 to 44.370829
Timon34, changed object longitude from 48.848098 to 48.845916
19 July 2020, 16:26:45
Timon34, changed object latitude from 44.370829 to 44.378296
Timon34, changed object longitude from 48.845916 to 48.843996
19 July 2020, 16:26:53
Timon34, changed object latitude from 44.378296 to 44.384691
Timon34, changed object longitude from 48.843996 to 48.842343
19 July 2020, 16:27:18
Timon34, changed object latitude from 44.384690 to 44.391664
Timon34, changed object longitude from 48.842343 to 48.840550
19 July 2020, 16:27:26
Timon34, changed object latitude from 44.391664 to 44.398509
Timon34, changed object longitude from 48.840550 to 48.838770
19 July 2020, 16:27:53
Timon34, changed object latitude from 44.398509 to 44.404625
Timon34, changed object longitude from 48.838770 to 48.837245
19 July 2020, 16:28:43
Timon34, changed object latitude from 44.404625 to 44.406964
Timon34, changed object longitude from 48.837245 to 48.836604
Timon34, changed warning direction from 311 to 291.
Timon34, changed object view angle from 30 to 20.
Timon34, changed object description from 'Автодория [Р-22 Каспий 949-951км]' to 'Астра-Трафик'.
19 July 2020, 16:29:05
Актуализация, установлена Астра-Трафик +1
19 July 2020, 16:29:11
19 July 2020, 16:29:14
19 July 2020, 16:36:16
Timon34, changed object latitude from 44.406964 to 44.406644
Timon34, changed object longitude from 48.836604 to 48.836685
Timon34, changed warning direction from 291 to 292.
19 July 2020, 16:45:12
См.выше.Актуально +1
19 July 2020, 16:45:20
31 August 2020, 09:00:11
25.07.2020 года в 08:51:28 по адресу ВОЛГОГРАДСКАЯ ОБЛАСТЬ, ГОРОДИЩЕНСКИЙ РАЙОН, ФАД Р-22 ТАМБОВ - ВОЛГОГРАД - АСТРАХАНЬ, 952 КМ водитель в нарушение п. 10.1, 10.3 ПДД РФ, управляя транспортным средством FОRD  государственный регистрационный знак *****134 свидетельство о регистрации транспортного средства *********, превысил установленную скорость движения транспортного средства на 26 км/ч, двигаясь со скоростью 116 км/ч при разрешенной скорости 90 км/ч на данном участке дороги .
31 August 2020, 10:03:13
Если поделитесь сканом штрафа, то это положительно скажется на Вашей карме.
06 September 2020, 11:24:48
Timon34, changed object description from 'Астра-Трафик' to 'Астра-Трафик [952км]'.
27 October 2020, 18:15:26
Timon34, changed object notification distance from 500 to 600.
04 May 2021, 10:07:45
04 May 2021, 10:08:13
Подтверждение штрафом +1
04 May 2021, 10:08:16
09 July 2021, 17:22:25
24 August 2021, 04:29:36
Вчерашний проезд показал, что камеры в оба направления в этом месте полностью демонтированы, включая боксы. Предлагаю пока не удалять, а перевести точки в тест. Еще месяц назад камеры прекрасно работали, штрафы сыпались как из рога изобилия, обе точки подтверждены июльскими штрафами
24 August 2021, 06:26:30
или в минус, точка удалится не скоро, через пол или год
24 August 2021, 10:35:02
Они уже давным давно не удаляются, так и висят в минусе
24 August 2021, 07:26:16
