21 November 2026, 00:53:28
03 September 2009, 20:14:29
15 September 2009, 13:40:09
21 October 2009, 18:46:37
antonN, changed warning direction from 130 to 145.
21 October 2009, 18:46:57
antonN, changed warning direction from 145 to 150.
15 November 2009, 16:15:26
antonN, changed warning direction from 150 to 153.
05 January 2011, 16:29:48
01 April 2013, 11:15:26
леха150, changed object latitude from 38.681986 to 38.682133
леха150, changed object longitude from 55.320540 to 55.320328
леха150, changed warning direction type from Two directions to In a certain direction.
01 April 2013, 11:16:26
не предупредит с поворота
15 February 2015, 20:05:36
а если предупредит?
16 February 2015, 07:42:38
1.6 При отметке объектов, которые стоят на изгибе дороги, вместо установки одной точки, надо установить две точки с направлением предупреждения в каждую сторону изгиба.
леха150, changed warning direction from 153 to 150.
леха150, changed object notification distance from 500 to 200.
16 November 2016, 14:20:37
S.Седой, changed warning direction type from In a certain direction to Two directions.
S.Седой, changed warning direction from 150 to 152.
S.Седой, changed object view angle from 15 to 30.
08 September 2018, 08:59:01
Alex_190, changed object latitude from 38.682133 to 38.682290
Alex_190, changed object longitude from 55.320328 to 55.320150
Alex_190, changed warning direction type from Two directions to In a certain direction.
Alex_190, changed warning direction from 152 to 333.
Alex_190, changed object notification distance from 200 to 120.
Alex_190, changed object view angle from 30 to 50.
22 January 2022, 19:57:22
рейтинг завышен, достаточно 1 -1
22 January 2022, 19:57:24
22 January 2022, 19:57:27
22 January 2022, 20:27:11
Выше -1
22 January 2022, 20:27:14
Выше -1
22 January 2022, 20:27:16
Выше -1
