21 November 2026, 02:11:42
Демонтирована
11 December 2016, 12:20:02
11 December 2016, 12:21:34
Раньше здесь гаишник стоял. Теперь треногу поставили
11 December 2016, 12:26:32
одна или пара?
11 December 2016, 12:22:07
sashasim, changed object view angle from 21 to 28.
11 December 2016, 12:28:19
обычно углы ставим с кратностью 5
11 December 2016, 12:25:57
sashasim, changed object latitude from 50.178353 to 50.178364
sashasim, changed object longitude from 53.372042 to 53.372073
11 December 2016, 12:30:15
11 December 2016, 12:32:30
ставьте две однонаправленные. не менее300м.
11 December 2016, 12:42:48
за фото вам +
11 December 2016, 12:30:34
и дистанция критическая (маленькая), можно не успеть среагировать. да и поворот вдобавок
11 December 2016, 12:36:14
sashasim, changed object latitude from 50.178364 to 50.178305
sashasim, changed object longitude from 53.372073 to 53.372044
sashasim, changed warning direction type from Two directions to In a certain direction.
sashasim, changed warning direction from 291 to 302.
sashasim, changed object notification distance from 233 to 440.
sashasim, changed object view angle from 28 to 31.
11 December 2016, 12:37:17
uDAV163, changed object notification distance from 440 to 450.
uDAV163, changed object view angle from 31 to 45.
11 December 2016, 12:39:16
uDAV163, changed object latitude from 50.178305 to 50.179061
uDAV163, changed object longitude from 53.372044 to 53.371914
11 December 2016, 12:40:15
Поставил за знак 40
11 December 2016, 12:43:55
uDAV163, changed warning direction from 302 to 295.
02 June 2018, 04:16:53
После реконструкции сняли знаки 40.
02 June 2018, 04:17:21
Возможная и треног больше не будет
02 June 2018, 06:19:20
удалить?
02 June 2018, 11:42:22
пусть пока постоит. только скорость надо поправить
04 June 2018, 17:16:21
Согласно списка мест установки новых камер тут должен автопатруль появится
09 June 2018, 17:05:31
uDAV163, changed object latitude from 50.179061 to 50.178498
uDAV163, changed object longitude from 53.371914 to 53.371988
uDAV163, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to   .
uDAV163, changed speed limit from 40 to 60.
uDAV163, changed object notification distance from 450 to 300.
uDAV163, changed object description from 'Контроль скорости' to 'Автопатруль Радар-С'.
09 June 2018, 17:05:51
uDAV163, changed object latitude from 50.178498 to 50.178788
uDAV163, changed object longitude from 53.371988 to 53.371943
24 July 2018, 18:12:35
демонтирован
29 July 2018, 23:40:01
 Отсутствует 30.7.18 1:00.
31 July 2018, 17:03:42
нету -1
20 September 2018, 14:13:40
uDAV163, changed object latitude from 50.178788 to 50.179201
uDAV163, changed object longitude from 53.371943 to 53.371895
uDAV163, changed speed limit from 60 to 40.
uDAV163, changed warning direction from 295 to 291.
uDAV163, changed object description from 'Автопатруль Радар-С' to 'Автопатруль Радар-С в спину'.
20 September 2018, 14:13:54
20 September 2018, 14:14:08
вернули +1
20 September 2018, 14:14:11
вернули +1
20 September 2018, 14:14:13
вернули +1
20 September 2018, 14:15:43
uDAV163, changed object latitude from 50.179201 to 50.179185
uDAV163, changed object longitude from 53.371895 to 53.371891
31 October 2018, 16:03:00
31 October 2018, 16:16:42
01 November 2018, 05:21:46
Штрафует. +1
01 November 2018, 05:21:59
Штрафует. +1
01 November 2018, 05:22:03
Штрафует. +1
22 November 2018, 00:20:39
uDAV163, changed object description from 'Автопатруль Радар-С в спину' to 'Автопатруль Радар-С (в спину)'.
20 December 2018, 03:17:19
17 November 2019, 00:43:14
Демонтирована -1
17 November 2019, 00:43:18
Демонтирована -1
17 November 2019, 00:43:21
Демонтирована -1
17 November 2019, 03:57:58
См. выше. Демонтаж. -1
17 November 2019, 03:58:02
17 November 2019, 03:58:05
21 November 2019, 09:31:55
21 November 2019, 09:32:00
21 November 2019, 09:32:04
21 November 2019, 15:46:00
21 November 2019, 15:46:06
21 November 2019, 15:46:11
21 November 2019, 16:20:57
uDAV163, changed object notification distance from 300 to 100.
uDAV163, changed object view angle from 45 to 10.
21 November 2019, 16:21:30
uDAV163, changed object description from 'Автопатруль Радар-С (в спину)' to 'Демонтирована'.
