05 October 2026, 10:10:04
For the past 24 hours: 56 objects added, 55 objects edited, 14 objects removed.
12 August 2019, 06:33:38
12 August 2019, 06:34:10
4
12 August 2019, 06:41:05
12 August 2019, 06:40:46
Yald, changed control area.
Yald, changed camera model.
12 August 2019, 10:44:56
Zenduri, changed object latitude from 37.312616 to 37.312596
Zenduri, changed object longitude from 55.981864 to 55.981863
Zenduri, changed control area.
02 September 2019, 06:02:27
02 September 2019, 09:46:10
02 September 2019, 11:41:12
Timon34, changed object description from 'АвтоУраган-ВСМ-2 (тыл)' to 'АвтоУраган-ВСМ-2 (тыл) [32км 659м]'.
02 September 2019, 11:41:50
Подтверждено +1
02 September 2019, 11:41:52
Подтверждено +1
02 September 2019, 11:41:55
Подтверждено +1
02 September 2019, 11:51:59
02 September 2019, 13:40:19
Это не АвтоУраган-ВСМ-2, это «СКАТ-С»
02 September 2019, 13:42:35
Ошибаюсь, висит АвтоУраган-ВСМ-2 типа Rn-Cam
03 September 2019, 16:32:51
03 September 2019, 16:33:11
 12.9 ч.3 - превышение установленной скорости движения транспортного средства на величину более 40, но не более 60 км/ч
03 September 2019, 16:32:52
04 September 2019, 05:14:38
Yald, changed object type from   to  Static speed camera Static speed camera.
04 September 2019, 05:14:53
Yald, changed object type from  Static speed camera Static speed camera to   .
04 September 2019, 05:15:38
Убрал "хвост". Уведомление о конце участка контроля будет приходить от idm=w-DBBk2gc1F
05 September 2019, 09:18:58
Подтверждено. +1
10 September 2019, 06:49:58
11 September 2019, 11:24:21
11 September 2019, 11:27:33
11 September 2019, 11:35:05
03 November 2019, 20:33:16
07 November 2019, 11:07:42
есть +1
28 December 2019, 12:05:14
Metallica.007, changed warning direction from 323 to 325.
Metallica.007, changed object notification distance from 500 to 700.
Metallica.007, changed object view angle from 15 to 20.
28 December 2019, 12:11:40
Metallica.007, changed warning direction from 325 to 323.
Metallica.007, changed object notification distance from 700 to 500.
05 April 2020, 14:49:45
09 April 2020, 21:25:16
26 April 2020, 07:56:50
04 May 2020, 12:58:23
arsenin, changed control area.
11 May 2020, 20:47:51
23 May 2020, 04:31:43
25 June 2020, 19:10:32
01 August 2020, 22:01:46
02 September 2020, 14:46:23
14 December 2020, 17:49:13
Завышен -1
26 December 2020, 16:34:21
26 December 2020, 16:36:51
500 метров- мало для такой трассы, даже для контроля в спину..
26 December 2020, 17:56:47
Для 150 км/ч достаточно 600 метров в для камер в тыл, а вот если ехать под 180 км/ч, еще 200 метров придётся добавить, но думаю основная масса водителей так не гоняет
26 December 2020, 17:50:01
MAGJoker, changed warning direction from 323 to 325.
MAGJoker, changed object notification distance from 500 to 600.
16 January 2021, 13:28:54
Завышает. Ехал по gps 129 км/ч, пришел штраф на 134 км/ч. Аналогичные настройки круиз-контроля - на других камерах все ок.
13 February 2021, 17:48:01
26 February 2021, 19:07:48
maykl3011, changed object type from   to  Lane Control Camera Lane Control Camera.
26 February 2021, 19:08:02
maykl3011, changed object type from  Lane Control Camera Lane Control Camera to   .
26 February 2021, 19:09:49
Убрал двойное оповещение . Конец зоны контроля оставил от парных камер.
18 June 2021, 22:36:25
25 April 2023, 10:14:13
25 April 2023, 10:14:17
25 April 2023, 10:14:21
25 April 2023, 11:35:49
Демонтаж. -1
25 April 2023, 11:35:54
Демонтаж. -1
25 April 2023, 11:35:59
Демонтаж. -1
25 April 2023, 15:32:49
Отсутствует. -1
25 April 2023, 15:32:54
Отсутствует. -1
25 April 2023, 15:32:59
Отсутствует. -1
25 April 2023, 16:42:59
25 April 2023, 16:43:24
007MCD, changed object notification distance from 600 to 100.
007MCD, changed object view angle from 20 to 10.
007MCD, changed object description from 'АвтоУраган-ВСМ-2 (тыл) [32км 659м]' to 'демонтаж'.
16 May 2024, 12:42:00
