22 October 2026, 03:52:16
дубль
23 January 2010, 19:38:59
04 February 2010, 16:04:02
Alex Co, changed speed limit from 40 to 20.
Alex Co, changed warning direction type from All directions (360) to Two directions.
04 February 2010, 16:04:05
Alex Co, changed warning direction from 40 to 124.
04 February 2010, 22:50:22
19 June 2010, 14:36:29
29 August 2011, 04:41:56
Заяц, changed object latitude from 37.664926 to 37.664925
Заяц, changed object notification distance from 500 to 150.
Заяц, changed object description from '' to 'Лежачий полицейский'.
15 May 2014, 18:18:39
леха150, changed speed limit from 20 to 40.
леха150, changed object notification distance from 150 to 130.
20 March 2015, 19:30:08
ozornik8888, changed object latitude from 37.664926 to 37.665129
ozornik8888, changed object longitude from 55.644256 to 55.644199
ozornik8888, changed speed limit from 40 to 20.
ozornik8888, changed warning direction from 124 to 125.
ozornik8888, changed object notification distance from 130 to 150.
09 October 2015, 08:39:02
NightWatcher, changed object latitude from 37.665129 to 37.665086
NightWatcher, changed object longitude from 55.644199 to 55.644178
05 September 2016, 04:51:33
, changed object latitude from 37.665086 to 37.665112
, changed object longitude from 55.644178 to 55.644208
, changed object notification distance from 150 to 120.
, changed object view angle from 15 to 30.
21 February 2019, 21:04:47
Рейтинг завышен -1
21 February 2019, 21:04:49
Рейтинг завышен -1
21 February 2019, 21:04:52
Рейтинг завышен -1
21 February 2019, 21:49:57
См. выше -1
21 February 2019, 21:50:00
См. выше -1
21 February 2019, 21:50:08
См. выше -1
01 January 2021, 14:25:51
arsenin, changed object notification distance from 120 to 100.
arsenin, changed object view angle from 30 to 20.
19 April 2023, 09:06:17
Добавил описание к другому лежачему полицейскому "три подряд", а этот надо удалить -1
19 April 2023, 09:06:21
19 April 2023, 09:06:24
16 June 2023, 07:53:06
См.выше. Удалил -1
16 June 2023, 07:53:09
См.выше. Удалил -1
16 June 2023, 07:53:11
См.выше. Удалил -1
17 June 2023, 14:25:08
kroxan, changed object description from 'Лежачий полицейский' to 'дубль'.
