05 November 2026, 03:18:53
Стрелка-М-П
01 December 2018, 15:35:24
01 December 2018, 15:36:14
Максимани, changed object description from 'Стрелка м-р' to 'Стрелка-м-р'.
01 December 2018, 18:29:42
Максимани, changed object latitude from 37.499473 to 37.499216
Максимани, changed object longitude from 55.853425 to 55.853352
Максимани, changed object notification distance from 188 to 179.
01 December 2018, 18:32:04
02 December 2018, 14:21:57
01 December 2018, 18:33:27
Висит после пешеходного перехода, возможно будет контролировать его   скорость
02 December 2018, 01:25:42
wolf-777, changed object description from 'Стрелка-м-р' to 'Стрелка-М-Р'.
02 December 2018, 01:33:53
wolf-777, changed object latitude from 37.499216 to 37.499008
wolf-777, changed object longitude from 55.853352 to 55.853309
wolf-777, changed warning direction from 239 to 237.
wolf-777, changed object notification distance from 179 to 300.
02 December 2018, 01:35:34
Немного прибавил, 179 м было мало, если есть контроль скорости.
02 December 2018, 14:23:43
Yald, changed camera model.
06 December 2018, 16:23:47
, changed object description from 'Стрелка-М-Р' to 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)'.
06 December 2018, 16:24:04
Рейтинг ноль -1
06 December 2018, 16:24:06
Рейтинг ноль -1
06 December 2018, 16:24:08
Рейтинг ноль -1
22 October 2019, 16:07:24
Ловит перестроение перед пешеходным переходом. +1
22 October 2019, 16:15:12
Аккуратней при выезде с Лавочкина направо перед левым поворотом на Ляпидевского, лучше перестравиваться после зебры. https://www.dropbox.com/s/hmlzid8h2b1s6ig/Flotskaya-44.png?dl=0
22 October 2019, 17:10:05
23 October 2019, 05:31:04
Asket1, changed object type from  Static speed camera Static speed camera to  Lane Control Camera Lane Control Camera.
Asket1, changed object description from 'МУЛЯЖ! Стрелка-М-Р (рейтинг ноль)' to 'Стрелка-М-П'.
Asket1, changed camera model.
Asket1, changed additional information (RU): \"
23 October 2019, 05:31:34
23 October 2019, 05:31:38
27 October 2019, 17:14:22
27 October 2019, 17:15:00
Включили, теперь дальше надо перестраиваться.
20 December 2019, 22:53:31
04 December 2020, 01:01:02
04 December 2020, 01:01:25
актуально +1
04 December 2020, 14:26:45
27 October 2021, 09:17:54
27 October 2021, 09:17:57
27 October 2021, 09:18:00
27 October 2021, 22:48:15
объект отсутствует -1
27 October 2021, 22:48:18
28 October 2021, 08:39:33
28 October 2021, 08:39:36
