22 October 2026, 07:31:25
Птолемей-СМ (в спину)
18 October 2018, 09:22:44
18 October 2018, 10:57:30
deksven_dair, changed object latitude from 36.173705 to 36.174655
deksven_dair, changed object longitude from 51.781471 to 51.781490
deksven_dair, changed control area.
deksven_dair, changed object type from   to   .
deksven_dair, changed speed limit from 50 to 60.
deksven_dair, changed speed limit from 0 to 60.
deksven_dair, changed warning direction type from Two directions to In a certain direction.
deksven_dair, changed warning direction from 339 to 160.
deksven_dair, changed object notification distance from 500 to 400.
deksven_dair, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Птолемей-СМ (в спину)'.
deksven_dair, confirmed object added via Mapcam.info program
18 October 2018, 10:59:06
18 October 2018, 11:00:35
09 May 2019, 19:56:52
09 May 2019, 19:59:02
09 May 2019, 19:59:07
09 May 2019, 19:59:11
13 May 2019, 05:41:13
deksven_dair, changed object latitude from 36.174655 to 36.174480
deksven_dair, changed object longitude from 51.781490 to 51.781779
26 March 2021, 07:23:39
26 March 2021, 07:24:02
с июня 20г. нет на зеркалах
11 December 2021, 13:06:35
неактуально, давно сняли -1
11 December 2021, 13:06:38
11 December 2021, 13:06:40
11 December 2021, 16:11:31
см выше, обнулил -1
11 December 2021, 16:11:33
см выше, обнулил -1
11 December 2021, 16:11:38
см выше, обнулил -1
12 December 2021, 01:54:45
12 December 2021, 01:54:47
12 December 2021, 01:54:49
