22 October 2026, 08:13:19
КРИС-П
13 July 2015, 11:04:59
03 August 2015, 07:34:43
tavot, confirmed object added via Mapcam.info program
03 August 2015, 10:54:45
Что здесь контролируют?
03 August 2015, 10:56:53
Спасибо, исправил.
03 August 2015, 10:56:00
tavot, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Контроль скорости'.
25 September 2015, 09:16:30
27 October 2015, 15:28:53
Narart, changed object latitude from 36.352474 to 36.352538
Narart, changed object longitude from 51.719813 to 51.719840
Narart, changed warning direction type from Two directions to In a certain direction.
Narart, changed warning direction from 268 to 273.
Narart, changed object view angle from 15 to 30.
Narart, changed object description from 'Контроль скорости' to 'КРИС-П'.
Narart, changed warning start time from 0 to 8.
Narart, changed warning end time from 24 to 20.
27 October 2015, 15:29:11
КРИС-П
КРИС-П
27 October 2015, 15:32:49
Есть КРИС-П +1
29 January 2017, 18:04:24
05 September 2021, 15:33:14
Неактуально -1
05 September 2021, 15:33:18
Неактуально -1
05 September 2021, 15:33:22
Неактуально -1
05 September 2021, 18:02:23
Неактуально -1
05 September 2021, 18:02:27
Неактуально -1
05 September 2021, 18:02:30
Неактуально -1
05 September 2021, 19:35:20
См.выше. Удалил. -1
05 September 2021, 19:35:22
См.выше. Удалил. -1
05 September 2021, 19:35:24
См.выше. Удалил. -1
