04 November 2026, 09:23:53
Бумеранг (BG0001/17-21)
01 June 2017, 12:46:12
01 June 2017, 12:46:52
01 June 2017, 12:47:18
01 June 2017, 12:49:17
Добавил парную к IDX: 896179
02 June 2017, 07:34:17
DiK57, changed control area.
DiK57, changed object notification distance from 500 to 300.
22 January 2018, 19:01:33
Теперь там 'Дозор-К'.Будьте внимательны!!!Радар-детектор его не видит.
22 January 2018, 19:15:16
 Фото или стопкадра с регистратора не осталось?
Или скан штрафа без личных данных - за фотоподтверждение + к карме
15 May 2018, 11:09:39
DiK57, changed camera model.
03 August 2018, 09:58:21
Здесь стоит другая камера цилиндрообразная маленькая
03 October 2018, 09:27:12
прохоров, changed object description from 'КРИС-С' to 'ДОЗОР-К'.
15 October 2018, 18:19:04
Timon34, changed object type from   to  Traffic control complex Traffic control complex.
15 October 2018, 18:20:56
Штраф за среднюю скорость https://mapcam.info/speedcam/point.php?idx=998940#comment_2207052 Остается открытым вопрос по скоростному режиму, судя по штрафу, должен быть 90 км/ч
15 October 2018, 18:28:48
Timon34, changed speed limit from 60 to 90.
Timon34, changed speed limit from 60 to 70.
15 October 2018, 18:43:28
15 October 2018, 18:57:17
Timon34, changed speed limit from 90 to 60.
Timon34, changed speed limit from 70 to 60.
15 October 2018, 18:57:52
16 October 2018, 08:05:54
Так не пойдет. Эту точку перевожу в участок контроля средней скорости, т.к. нарисован участок и добавлю камеру мгновенной (как сделано на M1), т.к. нету раздельного учета мгновенной и средней скорости.
16 October 2018, 08:07:12
DiK57, changed object type from  Traffic control complex Traffic control complex to  Twin camera Twin camera.
DiK57, changed speed limit from 60 to 90.
DiK57, changed speed limit from 60 to 70.
16 October 2018, 08:07:54
DiK57, changed object notification distance from 300 to 200.
16 October 2018, 08:09:28
DiK57, changed additional information (RU): \"
16 October 2018, 08:16:40
16 October 2018, 12:43:30
DiK57, changed object latitude from 31.237811 to 31.238150
DiK57, changed object longitude from 55.589830 to 55.589680
16 October 2018, 12:51:25
DiK57, changed object description from 'ДОЗОР-К' to 'Бумеранг'.
15 November 2018, 11:31:20
15 November 2018, 11:33:08
13 May 2019, 14:59:07
DiK57, changed object description from 'Бумеранг' to 'Дозор-К'.
13 May 2019, 14:59:29
DiK57, changed object latitude from 31.238150 to 31.238081
DiK57, changed object longitude from 55.589680 to 55.589705
25 August 2019, 20:25:35
yuryleb, changed object notification distance from 200 to 300.
14 November 2019, 06:19:10
14 November 2019, 09:07:02
Подтверждено штрафом. +1
14 November 2019, 09:07:08
14 November 2019, 09:07:20
Мото-рейтинг ноль. -1
15 November 2019, 07:49:17
DiK57, changed object description from 'Дозор-К' to 'Бумеранг'.
15 November 2019, 07:51:10
DiK57, changed object description from 'Бумеранг' to 'Бумеранг (BG0001/17-21)'.
27 May 2024, 09:13:00
24 October 2025, 07:02:13
Удаление -1
24 October 2025, 07:02:17
Удаление -1
24 October 2025, 07:02:20
Удаление -1
24 October 2025, 07:03:52
24 October 2025, 07:10:08
выше -1
24 October 2025, 07:10:09
выше -1
24 October 2025, 08:04:48
Выше Удалил -1
24 October 2025, 08:05:01
Выше Удалил -1
