22 October 2026, 02:58:39
24 January 2012, 02:02:44
24 January 2012, 02:36:02
eagles, changed object latitude from 132.917500 to 132.922001
24 January 2012, 02:36:03
eagles, changed object longitude from 48.796425 to 48.794702
eagles, changed warning direction from 119 to 300.
eagles, changed object notification distance from 383 to 390.
24 January 2012, 02:42:13
eagles, changed object latitude from 132.922001 to 132.918546
eagles, changed object longitude from 48.794702 to 48.796062
eagles, changed object notification distance from 390 to 100.
25 January 2012, 23:10:48
eagles, changed object latitude from 132.918546 to 132.935058
25 January 2012, 23:10:49
eagles, changed object longitude from 48.796062 to 48.790146
eagles, changed object type from  Speed limit sign Speed limit sign to  Speed Bump Speed Bump.
eagles, changed speed limit from 50 to 20.
eagles, changed warning direction type from In a certain direction to Two directions.
eagles, changed warning direction from 300 to 120.
eagles, changed object description from 'Ограничение скорости' to 'Лежачий полицейский'.
11 February 2015, 07:07:41
DiK57, changed warning direction from 120 to 116.
DiK57, changed object notification distance from 100 to 150.
07 July 2024, 23:53:04
не актуальная -1
07 July 2024, 23:53:08
не актуальная -1
07 July 2024, 23:53:11
не актуальная -1
08 July 2024, 03:39:32
Выше Удалил -1
08 July 2024, 03:39:36
Выше Удалил -1
08 July 2024, 03:39:39
Выше Удалил -1
08 July 2024, 03:39:56
