19 November 2026, 05:05:31
For the past 24 hours: 38 objects added, 66 objects edited, 18 objects removed.
добавить объект в Крыму - МОЖНО !!!
Ukraine > Крим
22 August 2022, 05:57:00
22 August 2022, 05:57:22
(R)ound, switched object to test mode
22 August 2022, 06:00:41
(R)ound, changed object latitude from 36.636143 to 36.629384
(R)ound, changed object longitude from 45.198067 to 45.199774
22 August 2022, 06:01:24
(R)ound, changed object latitude from 36.629384 to 36.621101
(R)ound, changed object longitude from 45.199774 to 45.202284
22 August 2022, 06:02:12
(R)ound, changed object latitude from 36.621101 to 36.612818
(R)ound, changed object longitude from 45.202284 to 45.206669
22 August 2022, 06:02:45
(R)ound, changed object latitude from 36.612818 to 36.607583
(R)ound, changed object longitude from 45.206668 to 45.215043
22 August 2022, 06:03:06
(R)ound, changed object latitude from 36.607583 to 36.602926
(R)ound, changed object longitude from 45.215043 to 45.224427
22 August 2022, 06:03:30
(R)ound, changed object latitude from 36.602926 to 36.596231
(R)ound, changed object longitude from 45.224427 to 45.229625
22 August 2022, 06:03:52
(R)ound, changed object latitude from 36.596232 to 36.589408
(R)ound, changed object longitude from 45.229625 to 45.234614
22 August 2022, 06:04:15
(R)ound, changed object latitude from 36.589408 to 36.582091
(R)ound, changed object longitude from 45.234614 to 45.240704
22 August 2022, 06:04:35
(R)ound, changed object latitude from 36.582091 to 36.576297
(R)ound, changed object longitude from 45.240704 to 45.244874
22 August 2022, 06:04:57
(R)ound, changed object latitude from 36.576297 to 36.570155
(R)ound, changed object longitude from 45.244874 to 45.248567
22 August 2022, 06:05:22
(R)ound, changed object latitude from 36.570155 to 36.564431
(R)ound, changed object longitude from 45.248567 to 45.253831
22 August 2022, 06:05:46
(R)ound, changed object latitude from 36.564431 to 36.557908
(R)ound, changed object longitude from 45.253831 to 45.258907
22 August 2022, 06:06:16
(R)ound, changed object latitude from 36.557908 to 36.552243
(R)ound, changed object longitude from 45.258907 to 45.264706
22 August 2022, 06:06:36
(R)ound, changed object latitude from 36.552243 to 36.546750
(R)ound, changed object longitude from 45.264706 to 45.270626
22 August 2022, 06:07:00
(R)ound, changed object latitude from 36.546750 to 36.540098
(R)ound, changed object longitude from 45.270626 to 45.275305
22 August 2022, 06:07:22
(R)ound, changed object latitude from 36.540098 to 36.535292
(R)ound, changed object longitude from 45.275306 to 45.281707
22 August 2022, 06:07:45
(R)ound, changed object latitude from 36.535292 to 36.527492
(R)ound, changed object longitude from 45.281707 to 45.285810
22 August 2022, 06:08:12
(R)ound, changed object latitude from 36.527492 to 36.519821
(R)ound, changed object longitude from 45.285810 to 45.291508
22 August 2022, 06:08:46
(R)ound, changed object latitude from 36.519821 to 36.512675
(R)ound, changed object longitude from 45.291508 to 45.293152
22 August 2022, 06:08:56
(R)ound, changed object latitude from 36.512675 to 36.505380
(R)ound, changed object longitude from 45.293152 to 45.296594
22 August 2022, 06:09:09
(R)ound, changed object latitude from 36.505380 to 36.498857
(R)ound, changed object longitude from 45.296594 to 45.299975
22 August 2022, 06:09:19
(R)ound, changed object latitude from 36.498857 to 36.493245
(R)ound, changed object longitude from 45.299975 to 45.303529
22 August 2022, 06:09:34
(R)ound, changed object latitude from 36.493245 to 36.485639
(R)ound, changed object longitude from 45.303529 to 45.307582
22 August 2022, 06:10:09
(R)ound, changed object latitude from 36.485639 to 36.477957
(R)ound, changed object longitude from 45.307581 to 45.310447
22 August 2022, 06:10:30
(R)ound, changed object latitude from 36.477957 to 36.471820
(R)ound, changed object longitude from 45.310447 to 45.312350
22 August 2022, 06:10:53
(R)ound, changed object latitude from 36.471820 to 36.464095
(R)ound, changed object longitude from 45.312350 to 45.316153
22 August 2022, 06:11:07
(R)ound, changed object latitude from 36.464095 to 36.458087
(R)ound, changed object longitude from 45.316153 to 45.321041
22 August 2022, 06:11:22
(R)ound, changed object latitude from 36.458087 to 36.454160
(R)ound, changed object longitude from 45.321041 to 45.324739
22 August 2022, 06:17:12
(R)ound, changed object description from 'Можно' to 'добавить объект в Крыму - МОЖНО !!!'.
22 August 2022, 08:44:57
Это как удалять гланды через задний проход
22 August 2022, 10:08:14
объясните как, я вот не пойму
22 August 2022, 10:09:40
кажись понял, точка в россии создана,  потом перемещена. Я тоже так думал, но двигать замучаешься. хоть и крым не большой но передвигать далеко не дает.
22 August 2022, 10:50:58
Двигать в несколько этапов
22 August 2022, 10:10:48
Точка ставиться на территории где она может ставиться (краснодарский край) и двигается в нужное место.
22 August 2022, 12:46:09
-2
А Вы через что практикуете?
30 January 2024, 12:20:51
Спам -1
30 January 2024, 12:20:54
Спам -1
30 January 2024, 12:20:57
Спам -1
30 January 2024, 16:00:31
30 January 2024, 16:00:33
30 January 2024, 16:00:36
