17 November 2026, 23:10:10
For the past 24 hours: 93 objects added, 89 objects edited, 13 objects removed.
Знак ограничения скорости
09 May 2016, 12:16:51
09 May 2016, 12:30:11
korall.vl, changed object latitude from 37.534730 to 37.534510
korall.vl, changed object longitude from 55.760031 to 55.759623
korall.vl, changed speed limit from 80 to 60.
korall.vl, changed warning direction from 16 to 18.
korall.vl, changed object notification distance from 500 to 100.
korall.vl, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Знак ограничения скорости'.
korall.vl, confirmed object added via Mapcam.info program
09 May 2016, 12:31:02
По нижнему ярусу ограничение 60
10 May 2016, 08:25:55
Сегодня меня ввела в заблуждение Ваша точка. Фонит при въезде на верхний уровень! Достаточно сообщения о засаде на 60 км/час.
10 May 2016, 09:24:49
Эта точка не фонит, час назад проезжал в левом ряду на верхний ярус. Фонит эта
10 May 2016, 09:25:37
Ее или удалить или корректировать
11 May 2016, 10:08:16
Фонят обе
11 May 2016, 10:41:27
Эта не фонит. Проезжал два раза вчера и сегодня при заезде на верхний ярус в левой полосе
11 May 2016, 10:45:18
korall.vl, changed warning direction from 18 to 19.
13 May 2016, 23:01:48
korall.vl, changed object latitude from 37.534510 to 37.534376
korall.vl, changed object longitude from 55.759623 to 55.759376
korall.vl, changed warning direction from 19 to 20.
20 March 2017, 19:45:04
korall.vl, changed warning direction from 20 to 21.
05 April 2017, 19:13:37
korall.vl, changed object latitude from 37.534376 to 37.534328
korall.vl, changed object longitude from 55.759376 to 55.759388
korall.vl, changed warning direction from 21 to 20.
30 October 2017, 17:48:51
korall.vl, changed object latitude from 37.534328 to 37.534274
korall.vl, changed warning direction from 20 to 23.
korall.vl, changed object notification distance from 100 to 130.
korall.vl, changed additional information (RU): \"
31 October 2017, 19:50:44
korall.vl, changed object latitude from 37.534274 to 37.534317
korall.vl, changed warning direction from 23 to 21.
30 December 2019, 10:41:14
Не актуально, знак 80 -1
30 December 2019, 10:41:21
30 December 2019, 10:41:25
22 May 2020, 11:53:45
не актуально. И камеры 60 нет
25 May 2020, 07:59:48
удалена см выше -1
25 May 2020, 11:32:25
Вы поторопились!
25 May 2020, 11:37:56
[url=https://yandex.ru/maps/213/moscow/?l=stv,sta
25 May 2020, 11:38:12
25 May 2020, 11:39:06
Ссылка не вставляется... Посмотрите на панорамах от 2020 года или на фото от 20.05.2020.
25 May 2020, 11:39:49
Yald, changed warning direction from 21 to 22.
25 May 2020, 11:40:03
Актуально. +1
