20 November 2026, 08:10:11
Азимут 4 [38км 014м]
16 May 2018, 12:09:19
16 May 2018, 12:08:50
Просьба занизить в 0
16 May 2018, 12:12:52
16 May 2018, 12:13:08
16 May 2018, 12:13:23
16 May 2018, 12:13:32
16 May 2018, 12:15:57
Ранее удаленная
https://mapcam.info/speedcam/point.php?idx=1054955
16 May 2018, 12:39:29
Уж лучше не удалять, иначе бдительные участники  будут ставить постоянно.
16 May 2018, 12:41:56
поэтому и установил в 2 местах. Камеру увидят-глаза большие, детектор пикнул значит на скорость))
16 May 2018, 12:31:58
Выше. -1
16 May 2018, 12:32:54
Спасибо
11 September 2018, 14:37:06
23 April 2019, 15:45:59
Прошу завысить рейтинг,  позже изменю тип и подкорректирую
23 April 2019, 16:08:01
serezhka, changed object latitude from 37.610895 to 37.610914
serezhka, changed object longitude from 55.422068 to 55.422047
serezhka, changed object type from  Lane Control Camera Lane Control Camera to  Static speed camera Static speed camera.
serezhka, changed warning direction from 12 to 5.
serezhka, changed object notification distance from 100 to 500.
serezhka, changed object description from 'Видеонаблюдение (рейтинг ноль)' to 'СКАТ-С'.
23 April 2019, 16:30:14
По просьбе +1
23 April 2019, 16:30:22
По просьбе +1
23 April 2019, 16:33:28
Благодарю
23 April 2019, 16:38:30
23 April 2019, 16:39:20
Перед СКАТОМ столб бывшей точки "Видеонаблюдение"
23 April 2019, 16:40:44
23 April 2019, 16:51:00
serezhka, changed object latitude from 37.610914 to 37.611013
serezhka, changed object longitude from 55.422047 to 55.422049
serezhka, changed warning direction from 5 to 4.
24 April 2019, 09:20:05
, changed object latitude from 37.611013 to 37.610943
, changed object longitude from 55.422049 to 55.422058
, changed warning direction from 4 to 7.
29 April 2019, 20:41:18
Все хорошо,  дублер - срабатывает,  основная -молчит.
14 May 2019, 17:20:24
18 October 2019, 13:26:54
Судя по всему штраф отсюда.
18 October 2019, 13:28:22
Подтверждайте фото, будем смотреть. Номера затрите.
18 October 2019, 13:27:40
18 October 2019, 20:20:10
Спасибо
18 October 2019, 20:21:00
serezhka, changed object description from 'СКАТ-С' to 'СКАТ-С (34км 014м)'.
18 October 2019, 20:21:23
serezhka, changed object description from 'СКАТ-С (34км 014м)' to 'СКАТ-С (38км 014м)'.
18 October 2019, 20:25:58
18 October 2019, 20:26:39
10 April 2021, 21:59:58
13 May 2021, 06:04:59
19 June 2021, 16:18:43
19 June 2021, 16:28:06
2maxic, changed object latitude from 37.610943 to 37.610808
2maxic, changed object longitude from 55.422058 to 55.421831
2maxic, changed warning direction from 7 to 5.
2maxic, changed object view angle from 10 to 15.
19 June 2021, 16:29:37
Меньше 15 градусов сработка неустойчивая.
19 June 2021, 16:41:00
Как только сделал всё было хорошо, потом с обновлениями приложений 2 последними, испортилось, сам залетел на свою)
19 June 2021, 16:46:17
Место стрёмное, думаю, можно для стабильности объединить вообще точки. Я так понял, камеры примерно рядом. Дробление не принципиально, главное получить предупреждение заранее и стабильно.
19 June 2021, 16:57:59
Да было нормально, и на основной не срабатывала, здесь аккуратно надо крутить. Говорю, после обновлений стали и на среднюю на параллельных срабатывать, которые не к этой дороге относятся. Крутить надо ювелирно. Как сделали сам проверял все четко было и на основной и на дублерах, а потом ложечки стали.
19 June 2021, 17:11:06
Неустойчивость связана с возможными перестроениями. В моменте угол машины к камере превышает угол предупреждения, поэтому оповещение может не работать или пропадать.
2maxic, changed object description from 'СКАТ-С (38км 014м)' to 'СКАТ-С [38км 14м]'.
29 June 2021, 22:08:48
Не срабатывает в левой полосе дублёра, уже не первый раз замечаю, в мае уже ловил тут, теперь оккуратничаю.
30 June 2021, 07:10:24
Жертвы неизбежны. Нужно точки объединить, пожертвовав корректностью ограничения скорости на автомагистрали. Лучше пусть срабатывает, чем нет.
30 June 2021, 08:02:52
Мой тоже выше, на свою же)) Подкорректировал, будем проверять.
30 June 2021, 07:59:01
serezhka, changed object latitude from 37.610808 to 37.610876
serezhka, changed object longitude from 55.421831 to 55.421779
30 June 2021, 09:35:01
Так будет хуже, при любом манёвре в полосе предупреждение пропадёт.
30 June 2021, 09:43:41
Буду проверять, если вы здесь часто, корректируйте по своему. Как выше писал, раньше до 2 последних обновлений было все нормально, потом смотрю на нескольких точках испортилось что работало идеально.
30 June 2021, 12:38:34
Может быть в ТТС добавить "на дублёре" ?
30 June 2021, 12:52:04
Проверим, посмотрим. При первоначальной установке специально проверял и дубрер и основную чтоб не фонило, все работало. Вот с весны произошел косяк
30 June 2021, 12:56:21
Вечером проедусь для проверки, посмотрю как левый ряд, если нормально, надо правый 6в основной будет смотреть ( на котором как буду для проезда ехать)
30 June 2021, 23:20:30
balabol.1974, changed object latitude from 37.610876 to 37.610829
balabol.1974, changed object longitude from 55.421779 to 55.421769
balabol.1974, changed warning direction from 4 to 7.
02 July 2021, 10:15:22
balabol.1974, changed object latitude from 37.610829 to 37.610865
balabol.1974, changed object longitude from 55.421769 to 55.421749
balabol.1974, changed warning direction from 7 to 4.
balabol.1974, changed object view angle from 10 to 15.
02 July 2021, 10:18:48
balabol.1974, changed object description from 'СКАТ-С [38км 14м]' to 'СКАТ-С [38км 014м]'.
04 July 2021, 11:45:16
balabol.1974, changed object latitude from 37.610865 to 37.610899
balabol.1974, changed object longitude from 55.421749 to 55.421748
05 July 2021, 07:32:27
balabol.1974, changed object latitude from 37.610899 to 37.610943
balabol.1974, changed object longitude from 55.421748 to 55.422058
07 July 2021, 07:14:02
balabol.1974, changed object latitude from 37.610943 to 37.610956
balabol.1974, changed object longitude from 55.422058 to 55.422059
07 July 2021, 21:54:07
Все отлично теперь левая полоса.
19 March 2022, 20:50:08
serezhka, changed speed limit from 90 to 70.
20 March 2022, 20:30:02
serezhka, changed speed limit from 70 to 90.
13 April 2022, 12:08:59
Нет предупреждения, не в левой не в правой
13 April 2022, 12:15:06
balabol.1974, changed object latitude from 37.610956 to 37.611006
balabol.1974, changed object longitude from 55.422059 to 55.422056
26 April 2022, 15:43:14
balabol.1974, changed object latitude from 37.611006 to 37.610916
balabol.1974, changed object longitude from 55.422056 to 55.421775
02 May 2022, 16:24:37
balabol.1974, changed object latitude from 37.610917 to 37.610904
balabol.1974, changed object longitude from 55.421775 to 55.421776
23 May 2022, 20:47:07
Проверено, левый ряд, срабатывает.
02 August 2022, 09:53:07
serezhka, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
02 August 2022, 22:24:04
serezhka, changed object type from  Traffic control complex Traffic control complex to  Static speed camera Static speed camera.
30 September 2022, 14:33:21
У всех срабатывает? На каком расстоянии, я теперь после заправки  оттормаживаюсь, тк нет предупреждения
30 September 2022, 15:43:42
Вчера проверял, левый ряд, все замечательно.
08 October 2022, 11:38:51
А за сколько метров?
08 October 2022, 11:45:36
От заправки, в принципе как и луч установлен. Больше подкручивать смысла не или делать чтоб на основной сработала была и тогда прописывать где установлена, но опять повторюсь, что у меня после последней подкрутки отрабатывает.
30 September 2022, 15:44:37
serezhka, changed object description from 'СКАТ-С [38км 014м]' to 'Азимут 4 + СКАТ-С [38км 014м]'.
02 February 2023, 17:11:18
serezhka, changed object description from 'Азимут 4 + СКАТ-С [38км 014м]' to 'Азимут 4 [38км 014м]'.
02 February 2023, 17:11:34
