21 October 2026, 22:46:18
For the past 24 hours: 67 objects added, 40 objects edited, 9 objects removed.
АвтоУраган-ВСМ-2 [51км 298м]
30 March 2019, 05:32:55
30 March 2019, 12:23:26
HarmanKardon, changed speed limit from 90 to 70.
16 April 2019, 16:51:08
Фото упростило бы идентификацию.
17 April 2019, 18:09:05
В выходные буду проезжать, сделаю
26 April 2019, 19:56:11
27 April 2019, 13:17:38
Спасибо. Плюс к карме.
27 April 2019, 14:21:35
Спасибо
27 April 2019, 13:16:20
, changed object description from 'Новая камера. работает или нет, не знаю. Установили недавно' to 'АвтоУраган-ВСМ-2'.
27 April 2019, 13:16:42
Для мото ноль. -1
27 April 2019, 13:16:54
27 April 2019, 13:18:25
, changed warning direction from 27 to 25.
, changed object notification distance from 407 to 500.
29 April 2019, 07:55:28
wxolms, changed warning start time from 8 to 0.
wxolms, changed warning end time from 24 to 0.
29 April 2019, 07:56:30
wxolms, changed warning end time from 0 to 24.
17 May 2019, 08:38:53
Камера работает!
17 May 2019, 08:51:27
Опять как то не так
17 May 2019, 08:55:12
17 May 2019, 08:59:41
Спасибо.
17 May 2019, 08:58:14
Вот теперь правильно. Как ошибочно загруженное фото удалить?
18 July 2019, 13:10:58
18 July 2019, 13:11:20
Ashkrmane, changed object description from 'АвтоУраган-ВСМ-2' to 'АвтоУраган-ВСМ-2 [51км 235м]'.
18 July 2019, 13:11:26
18 July 2019, 13:11:29
13 August 2019, 09:15:05
22 August 2019, 07:36:55
Спасибо! Плюс к карме.
22 August 2019, 07:49:13
Ashkrmane, changed object type from  Static speed camera Static speed camera to  Traffic control complex Traffic control complex.
07 September 2019, 23:32:37
24 September 2019, 11:47:15
24 September 2019, 15:48:52
arsenin, changed object notification distance from 500 to 750.
24 October 2019, 07:03:59
Внимание!!! Камера работает не корректно, прибавляет 5-6 км/ч Еду всю дорогу на круизе 107-109, получил 3 штрафа подряд  Будьте аккуратнее.
01 November 2019, 07:27:39
Вы свою скорость измеряли по GPS? Круиз ведь работает по показаниям вашего датчика скорости, а он может иметь неточность (размер колес и т. п.)
24 October 2019, 07:07:39
24 October 2019, 07:10:51
27 October 2019, 15:44:23
27 October 2019, 15:44:55
27 October 2019, 15:47:35
Добавили ещё одну камеру. Вроде АУ. Может для фиксации ещё одного участка?
29 October 2019, 06:30:26
Может сравнивают показания...
01 November 2019, 07:30:59
Автор, просьба увеличить угол обзора, чтобы изгиб дороги входил. Как имеется сейчас при движении со стороны Сергиева Посада сообщение появляется, затем пропадает, когда выходишь за пределы стрелки, и еще раз появляется
01 November 2019, 07:42:54
Ashkrmane, changed warning direction from 25 to 30.
Ashkrmane, changed object notification distance from 750 to 500.
Ashkrmane, changed object view angle from 25 to 45.
04 November 2019, 15:30:22
Старый АУ демонтировали.
04 November 2019, 15:32:10
04 November 2019, 15:46:31
04 November 2019, 15:47:24
04 November 2019, 15:48:34
04 November 2019, 15:49:38
04 November 2019, 15:50:42
текущий вид.
20 November 2019, 13:22:44
Скорее всего, камера начала менять среднюю скорость от камеры, расположенной на  52км 950м
20 November 2019, 17:29:05
Приветствую. Подтверждения есть? Торопиться не стОит.
20 November 2019, 18:06:50
20 November 2019, 19:51:28
Тема!
20 November 2019, 20:50:08
Перенесите пожалуйста Ваше фотоподтверждение в эту точку  https://mapcam.info/speedcam/point.php?idm=Xgx6WP_BRX7 Спасибо.
21 November 2019, 07:22:53
На парных камерах есть начало и конец участка. На фото начало участка, с правой стороны конец. Выкладывайте полную информацию!
20 November 2019, 13:24:15
HarmanKardon, changed object type from  Traffic control complex Traffic control complex to  Twin camera Twin camera.
20 November 2019, 20:12:59
Сможете сами оформить парные точки по аналогии с этой? https://mapcam.info/speedcam/point.php?idm=PjTSs0ksT-i
20 November 2019, 20:14:33
Не смогу) не в курсе как это делается)
20 November 2019, 20:16:36
т.е не менять тип этой точки, а добавить еще одну в начало контроля и дотянуть хвост до текущей Вашей.
20 November 2019, 17:26:54
abbc, changed object type from  Twin camera Twin camera to  Traffic control complex Traffic control complex.
20 November 2019, 21:08:55
Спасибо
24 November 2019, 13:40:20
24 November 2019, 13:40:39
25 November 2019, 15:19:45
sos_Cuba, changed object description from 'АвтоУраган-ВСМ-2 [51км 235м]' to 'АвтоУраган-ВСМ-2 [51км 298м]'.
06 January 2020, 08:47:09
точка выставлена немного НЕ корректно столб на котором смонтирована камера проезжаем....а предупреждение ещё продолжает пищать как приближение
06 January 2020, 09:54:51
setpiton, changed object latitude from 38.005625 to 38.005892
setpiton, changed object longitude from 56.139671 to 56.139944
setpiton, changed warning direction from 30 to 27.
06 January 2020, 12:44:04
06 January 2020, 12:44:24
место установки предупреждающих знаков
06 January 2020, 12:45:51
06 January 2020, 12:46:13
а вот и сама камера
29 August 2020, 10:18:52
Пришел штраф за обочину
31 August 2020, 10:36:51
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAABZAAAAK CAYAAAA8KDuVAAAgAElEQVR4Aezdh7OlS1X4ff8Py0Aw55xzzjnnSM7hkoOgRAUEVIICIiBBokghCoIKIioqilUIqKACBlBBBUX3W5/nV1/eZdezz5wzMwz3wpmqrtW9evVK3b26e 199rzf6173usPHfdzHHT7yIz/y8NEf/dGHD/uwDztc 9rXPnzMx3zMhoN/Xy0f9VEfdXh3FH4 Vk6Sd2wM/Md 7Mduc2betONj7qrrQ3faMvnEI5jMySvZ tQvpXz8x3/8ti6tzWSQjXf8q8OjSV792uHh0OWPSdO4FU7Z6XBWGM85buKqB8ncK/wRDV5o4JRP IRP2ErjkhVNeLC eIErv/jOcWudzE/6pE/ayid 4ie S35 XulP244X/vRIN PTfeJWXac/1I0Lh3c6g9onlfw6daoebzTxmDwbO Eca/zUKx7hGteYYPgV5l/4yYuv4D7lUz7l8Bmf8RmHz/7szz583ud93uELvuALDl/0RV90 PzP//ytDYb74i/ 4sOXfumXHr7kS77koL5X9H3FV3zF4cu//MvfRYsfHvH8nM/5nMNnfdZnbeUzP/MzD5/ 6Z9  NRP/dTN7uaTvVPfaefqI/795E/ 5M0W9jSX6pU5B/Ft3ByrrsSDj7Q/7dM bdMzXevHn 71s4dtfFrRp/65n/u57/IBf8Oh5/cv/MIv3Pyer/hIX/z4Dx08P37Zl33Z4Su/8ivfVb7u677u8I3f I1b27zw/7d 67cevu3bvu3w9V//9Yev ZqvOXzzN3/z4Tu 4zsO3/7t377V9X/Lt3zLwVi4G9/4xoerrrrqcPOb3/zwgz/4g9vY7/3e7z1c//rXP3z3d3/34Ru 4Rs2WvTf//3ff/jhH/7hw/d93/cd0FzvetfbxqAh77u 67u2/h/4gR/YZNGX3l/7tV 78aGLQudv qZv2nTFB1 y6POd3/mdW8mGr
31 August 2020, 10:37:24
31 August 2020, 08:57:31
Пришёл штраф за скорость с этой камеры
31 August 2020, 11:34:49
08 February 2021, 14:10:43
08 February 2021, 14:12:31
08 February 2021, 14:12:54
15 July 2021, 11:28:34
Yald, changed warning direction from 27 to 24.
Yald, changed object notification distance from 500 to 700.
21 September 2021, 13:43:00
15 July 2022, 11:37:09
21 July 2022, 09:10:48
проезжал еще пару раз там, нет предупреждения о камере. кто там бывает, у вас как?
10 May 2023, 09:33:50
Тоже для себя отметил, что уведомления о камере мапкам не выдает. Почему и, что делать, вот в чем вопрос?
10 May 2023, 09:33:52
10 May 2023, 09:47:50
У меня всё норм. И визуально и аудио. Может в пробке стояли. Ниже 20-ти озвучки нет.
10 May 2023, 10:49:42
Проблема была в последней версии мапкам, откатился на предпоследнюю и все стало норм
10 May 2023, 10:49:43
10 May 2023, 09:48:12
42OI339O, changed object latitude from 38.005892 to 38.005947
42OI339O, changed object longitude from 56.139944 to 56.139936
42OI339O, changed warning direction from 24 to 21.
42OI339O, changed object notification distance from 700 to 600.
10 September 2023, 19:31:15
10 September 2023, 19:31:33
19 September 2023, 13:06:54
19 September 2023, 13:07:08
достаточно 2-ух -1
27 April 2024, 17:32:33
01 July 2024, 14:19:03
пришел штраф +1
01 July 2024, 15:12:04
Рейтинг 2 -1
11 July 2025, 19:40:46
22 September 2025, 05:02:57
22 September 2025, 05:05:07
22 September 2025, 08:55:55
завышен -1
