22 October 2026, 06:19:58
КОРДОН (тыл)
22 October 2019, 11:16:23
22 October 2019, 11:23:27
Valfon, changed object latitude from 39.228680 to 39.228755
Valfon, changed object longitude from 51.685148 to 51.684774
Valfon, changed warning direction from 19 to 8.
Valfon, changed object view angle from 25 to 44.
23 October 2019, 05:20:00
Yald, changed object latitude from 39.228755 to 39.228667
Yald, changed object longitude from 51.684774 to 51.684805
Yald, changed control area.
Yald, changed object view angle from 44 to 45.
Yald, changed object description from 'КОРДОН' to 'КОРДОН (тыл)'.
Yald, changed camera model.
14 May 2020, 07:35:27
14 May 2020, 07:35:47
Подтверждено штрафом +1
14 May 2020, 07:35:49
14 May 2020, 07:35:52
10 October 2020, 12:31:31
silandser, changed warning direction from 8 to 19.
silandser, changed object notification distance from 250 to 350.
silandser, changed object view angle from 45 to 60.
02 June 2022, 10:54:06
Камеру убрали. Точку в "тест"
02 June 2022, 10:54:52
Камера отсуттвует -1
02 June 2022, 10:55:13
Камера отсутствует -1
02 June 2022, 10:55:21
02 June 2022, 18:41:46
См выше -1
02 June 2022, 18:41:49
См выше -1
02 June 2022, 18:41:51
См выше -1
19 June 2022, 03:43:36
Отсутствует -1
19 June 2022, 03:43:39
Отсутствует -1
19 June 2022, 03:43:41
Отсутствует -1
27 June 2022, 19:51:20
silandser, changed object notification distance from 350 to 100.
silandser, changed object view angle from 60 to 10.
