22 October 2026, 08:12:16
Войныха
Ukraine > Полтавська область
24 October 2010, 16:40:35
02 November 2010, 19:21:29
Max_rl, changed object latitude from 33.073139 to 33.071895
Max_rl, changed object longitude from 49.956908 to 49.957681
30 November 2010, 19:44:48
Max_rl, changed object latitude from 33.071895 to 33.070865
Max_rl, changed object longitude from 49.957681 to 49.958316
07 February 2011, 20:34:22
Max_rl, changed object type from  Speed limit sign Speed limit sign to  The beginning of inhabited locality The beginning of inhabited locality.
07 November 2011, 20:03:58
Max_rl, changed object latitude from 33.070865 to 33.070865
07 November 2011, 20:04:14
Max_rl, changed object latitude from 33.070865 to 33.070929
Max_rl, changed object longitude from 49.958316 to 49.958344
07 November 2011, 20:04:30
Max_rl, changed object latitude from 33.070929 to 33.071036
07 November 2011, 20:04:41
Max_rl, changed object latitude from 33.071036 to 33.070886
Max_rl, changed object longitude from 49.958344 to 49.958357
07 November 2011, 20:04:55
Max_rl, changed object latitude from 33.070886 to 33.070972
Max_rl, changed object longitude from 49.958357 to 49.958288
07 November 2011, 20:05:01
Max_rl, changed object latitude from 33.070972 to 33.070972
16 April 2012, 10:26:18
Max_rl, changed warning direction from 133 to 132.
07 January 2013, 14:52:37
Max_rl, changed object description from 'НП Войниха' to 'Войниха'.
06 October 2017, 19:17:35
KyzjaTV, changed object description from 'Войниха' to 'Войныха'.
KyzjaTV, changed additional information (RU): \"
04 July 2019, 17:50:10
KyzjaTV, changed object latitude from 33.070972 to 33.071087
KyzjaTV, changed object longitude from 49.958288 to 49.958332
KyzjaTV, changed warning direction from 132 to 134.
KyzjaTV, changed object view angle from 15 to 20.
30 July 2021, 11:44:37
31 July 2021, 09:10:17
Больше не нужна. -1
31 July 2021, 09:10:20
Больше не нужна. -1
31 July 2021, 09:10:22
Больше не нужна. -1
26 August 2021, 08:00:59
См.выше. Удалил. -1
26 August 2021, 08:01:01
См.выше. Удалил. -1
26 August 2021, 08:01:03
См.выше. Удалил. -1
