22 October 2026, 05:45:44
Мобильная камера (засада), контроль скорости
12 March 2012, 15:32:37
12 March 2012, 15:50:02
Чего так криво то луч смотрит? Отрегулируй, что бы все было красиво )
13 March 2012, 14:37:10
Alex Wise, changed warning direction from 190 to 196.
Alex Wise, changed object notification distance from 500 to 200.
Alex Wise, changed object description from 'Камера, установленная на треноге' to 'Камера, установленная на штативе'.
01 May 2012, 05:33:26
, changed object latitude from 42.099818 to 42.100536
, changed object longitude from 61.075873 to 61.076797
, changed warning direction from 196 to 198.
, changed object notification distance from 200 to 300.
, changed object description from 'Камера, установленная на штативе' to 'Мобильная камера (засада), контроль скорости'.
01 May 2012, 05:35:44
Треноги давно не видно, очень часто стоят на этом перекрёстке.Дистанция и о треноге предупредит если снова будут ставить.
09 September 2012, 17:11:05
, changed object latitude from 42.100536 to 42.100536
, changed warning direction from 198 to 195.
, changed object notification distance from 300 to 420.
09 September 2012, 17:11:49
Поправил
13 November 2015, 09:56:51
09 July 2016, 21:29:27
NightWatcher, changed warning direction from 195 to 197.
11 February 2025, 17:39:01
не актуальна -1
11 February 2025, 17:39:03
не актуальна -1
11 February 2025, 17:39:05
не актуальна -1
11 February 2025, 18:56:10
11 February 2025, 18:56:12
11 February 2025, 18:56:14
11 February 2025, 18:56:26
, changed object notification distance from 420 to 100.
