03 October 2026, 14:16:03
For the past 24 hours: 24 objects added, 25 objects edited, 7 objects removed.
Муляж КРИС-С
01 October 2019, 04:53:33
01 October 2019, 09:24:54
mihan11, changed object latitude from 30.638011 to 30.638426
mihan11, changed object longitude from 60.034981 to 60.035058
mihan11, changed speed limit from 40 to 60.
mihan11, changed speed limit from 0 to 60.
mihan11, changed warning direction type from Two directions to In a certain direction.
mihan11, changed warning direction from 44 to 65.
mihan11, changed object notification distance from 500 to 250.
mihan11, changed object view angle from 15 to 65.
mihan11, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Кордон М4'.
mihan11, confirmed object added via Mapcam.info program
mihan11, changed camera model.
mihan11, changed additional information (RU): \"
01 October 2019, 09:25:30
01 October 2019, 09:27:25
Повесили Кордон М4, пока не подключён. Скорее всего на сплошную. Извините за качество фото, нелётная погода.
01 October 2019, 09:39:04
Мото-рейтинг ноль. -1
02 October 2019, 09:21:02
mihan11, changed object type from  Traffic control complex Traffic control complex to  Static speed camera Static speed camera.
mihan11, changed object description from 'Кордон М4' to 'Статическая камера, измеряющая скорость'.
02 October 2019, 09:24:08
mihan11, changed object latitude from 30.638426 to 30.638412
mihan11, changed object longitude from 60.035058 to 60.035082
mihan11, changed object description from 'Статическая камера, измеряющая скорость' to 'КРИС-С'.
12 October 2019, 16:57:44
mihan11, changed object description from 'КРИС-С' to 'Муляж КРИС-С'.
12 October 2019, 17:04:40
По информации источника, близкого к районной администрации, заключен контракт на установку полутора десятка активных муляжей камер. Это один из них. Для активации даже солнечную батарею прицепили, правда, пока не в работе. Нужен минус.
14 October 2019, 09:41:23
14 October 2019, 09:44:09
Подключили батарею. Заработал РД. Смотрит, правда, куда-то вверх, да и разрешённую скорость превысить здесь крайне тяжело.
14 October 2019, 09:48:48
Муляж -1
14 October 2019, 09:48:51
Муляж -1
