16 November 2026, 00:40:37
Знак ННП 5.23.2
20 October 2016, 13:16:30
21 October 2016, 19:03:57
stroy82, changed object type from   to  Speed limit sign Speed limit sign.
stroy82, changed speed limit from 80 to 60.
stroy82, changed warning direction type from Two directions to In a certain direction.
stroy82, changed object notification distance from 500 to 400.
stroy82, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'Знак ННП'.
stroy82, confirmed object added via Mapcam.info program
21 October 2016, 19:05:23
stroy82, changed warning direction from 16 to 11.
stroy82, changed object notification distance from 400 to 390.
stroy82, changed object view angle from 15 to 25.
25 October 2016, 08:06:56
25 October 2016, 08:08:46
stroy82, changed object description from 'Знак ННП' to 'Знак ННП 5.23.2'.
07 November 2016, 20:49:05
stroy82, changed warning direction from 11 to 12.
stroy82, changed object notification distance from 390 to 321.
14 November 2016, 19:09:33
NikAndr, changed object type from  Speed limit sign Speed limit sign to  The beginning of inhabited locality The beginning of inhabited locality.
NikAndr, changed additional information (RU): \"
14 November 2016, 19:14:34
Едем в Архангельск
Едем в Архангельск
14 November 2016, 21:46:11
Отмечаются НП только на синем фоне.
14 November 2016, 21:49:08
P.S. С обратной стороны обозначения Исакогорки нет...
15 November 2016, 15:38:35
Так это встречное направление!
14 November 2016, 21:43:17
У нас полный бардак со знаками, или какое-то новшество...
15 November 2016, 15:40:01
Видимо, под западные стандарты. В Эстонии этот знак активно используется. Причем по-человечески: сначала название НП на синем фоне, а уже когда нужно - тогда этот знак.
Начало Северодвинска так бы надо было сделать :(
14 November 2016, 21:46:43
stroy82, changed object type from  The beginning of inhabited locality The beginning of inhabited locality to  Speed limit sign Speed limit sign.
15 November 2016, 15:38:02
Так с противоположной стороны всё-таки какой знак - "60", или 5.23.2?
15 November 2016, 20:33:13
Не вижу разницы для водителей.
16 November 2016, 13:28:18
Знаки "Начало населённого пункта" отмечаем типом "Начало населённого пункта".
16 November 2016, 13:41:11
Разница для водителей есть.
16 November 2016, 16:34:58
Разница принципиальная.
Знаки 5.23.1 и 5.23.2 - это один и тот же знак начала НП (в двух разновидностях) со всеми вытекающими последствиями. Например, знак "60" будет отменен ближайшим перекрестком, знаки 5.23 действуют до появления отменяющего их знака. Знак начала НП разрешает свободное движение по 2-й полосе, знак "60" его запрещает (вспомним Рикасиху...). И т. д.
Кроме того - говорят, что в MCD действует переключение режимов трасса/город на основании знаков НП.
16 November 2016, 16:56:19
Да, соглашусь. Просто подозреваю, что это у них не окончательная расстановка знаков. Всё что-то перетаскивают, перекручивают. До нынешнего года территория дороги в этом месте была частью Приморского района, и ни в какой НП не входила, а сейчас вот знак 5.23.2. Ладно, поживём - увидим.
16 November 2016, 16:58:24
Кстати, стенды границы Приморского и Холмогорского р-нов передвинули к Москве на 1.1 км...
16 November 2016, 16:56:48
stroy82, changed object type from  Speed limit sign Speed limit sign to  The beginning of inhabited locality The beginning of inhabited locality.
16 November 2016, 17:00:23
valur111, changed object notification distance from 321 to 250.
valur111, changed object view angle from 25 to 45.
16 November 2016, 17:01:09
Дистанция до idx=172875, сектор для кнп.
16 November 2016, 17:04:24
Я бы ещё в описании и в доп.инфо написал бы не "Знак ННП 5.23.2", а "Зелёный Бор". Местным на усмотрение.
06 August 2021, 22:14:48
stroy82, changed warning direction from 12 to 6.
stroy82, changed object notification distance from 250 to 499.
stroy82, changed object view angle from 45 to 25.
05 January 2023, 12:03:08
NikAndr, changed object latitude from 40.603630 to 40.603546
NikAndr, changed object longitude from 64.451219 to 64.451106
05 January 2023, 12:04:36
05 January 2023, 12:19:10
NikAndr, changed object notification distance from 499 to 300.
05 January 2023, 12:20:14
Подробности см. здесь.
05 January 2023, 12:23:39
Да что за напасть! Ещё раз правильная ссылка.
